Old 01-03-2012, 03:33 PM   #1
Slideout not functioning
Used the trailer for the first time this weekend and it was flawless.. got it home and now the slideout will not operate. Checked all fuses, all switches have power, power from camper to house is good.
Trailer is a 2010 8280ws.
Next step is checking the motor but it looks like a PITA to get to so I figured I would ask her first.
Thanks in advance.
Ryan
rnaz is offline   Reply With Quote
Old 01-03-2012, 05:35 PM   #2
Follow the positive lead of the battery down by the tongue, and somewhere you should find a circuit breaker. It will have a VERY SMALL reset button on it. The positive lead will be screwed to a stud, and another lead screwed to the other stud. The reset button will be either top, or bottom, depending on how they installed it.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 01-03-2012, 09:14 PM   #3
THANK YOU!!! Followed the lead like you said and came to a small plastic pouch which had a 30 amp fuse. Pulled fuse and it was blown. Replaced and works again!
