If you crawl under the slide while open, you'll see the bolts holding the room to the push/pull arms. You will need HELP holding the room up, and you will need to remove the lip seal to get the room out. These things are bulky and heavy, so again, don't attempt this without some adequate help!! But it can be done. Randy
