I had a grey wolf, pretty sure there's no cranking. They say you push it manually, but from past discussions on here, I believe I'm right with the power thing. I think you need to pull the lower fascia off the slide, and access the motor under there. I wonder if a simple fuse pull would work as well though?
Again, I'm not 100% sure.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
