Old 10-28-2010, 04:28 PM   #1
slideout warning!
If you have a slideout with the retractable power cord on a 1/4 inch steel support rod check for rubs in open and closed position mine was rubbing the copper propane lines to the point of almost leaking !
It was repaired with 1/2 inch pvc conduit sleve over the rod
a rubber hose sleve for the copper and 2 wire ties
Not to mention the brake brakeaway switch thatwas TAPED ON
YOUR BEST FRIEND IS A GARAGE CREAPER AND A THROUGH INSPECTION
2007 cherokee 30f
G.A. Kelley is offline   Reply With Quote
Old 10-28-2010, 07:13 PM   #2
we had a slider bend the hydrolic ram, and the slider was stuck in the open position. anyone else have the same issue?
ohiodude is offline   Reply With Quote
Old 10-28-2010, 07:25 PM   #3
Boyd's Avatar
Big Bang Theory Exposed
2007 cherokee 30f
I don't know what kind of rig you have but that sure sounds like a definite RECALL issue. You and your neighbors life are totally compromised with potential leaking propane.
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
