Old 10-13-2018, 03:17 PM   #1
Slideout will not extend
Hey guys, I have a 2001 Wildwood 29BHSS and am a newbie. The slide will not go out, when you push the switch you can not here the motor turn on. The lights inside the slide are work so not sure if the slide mechanism just isn't getting power. Also does it have a manual crank to move it out in the event of a power failure?
firefighter45692 is offline   Reply With Quote
Old 10-13-2018, 07:27 PM   #2
Head Rambler
I know you said that the lights work, but is the battery charged fully?
Do the lights dim when you press the slide switch?
There's usually a resettable breaker near the battery for the slide. It's usually under the frame if it's a TT or in the front storage area if your unit is a fifth wheel.
Gotta go campin!
Old 10-13-2018, 07:55 PM   #3
So I have spent the evening investigating. The fuses and breakers are all good, so now I am thinking either the in/out switch or the silenoid on the hydro pump is bad because the pump is not doing anything.
Next, there is no manual out, only an emergency hand pump back in which I find aggravating.
So to get the slide out I switched the lines on the pump and manual put it out till I can further diagnose the pump.
Old 10-13-2018, 08:18 PM   #4
Head Rambler
Did you check for 12 volts at the solenoid while the switch is pressed?
Gotta go campin!
Old 10-13-2018, 08:40 PM   #5
cavie's Avatar
There are no breakers involved with your slides. Slides are 12 volts. Breakers are 120. Did you find the INLINE fuses near the battery? Slide fuses are not on the converter. They usually are resettable with a little button on the side. Do you have a battery disconnect? If so, it ON?
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 10-14-2018, 09:20 AM   #6
We got this..
No I hadn't made it that far yet. I have checked the the fuse and it's good. I am going to check today to see if it's getting the 12v to the pump if not i will start tracing back..
Old 10-26-2018, 01:09 AM   #7
It might be seals on the inside of the hydraulic ram. I have a 2000 Wildwood 5th wheel with 2 slides. My living room slide would not move, yet the smaller bedroom would extend or retract easily. So took the main slide ram off and had it rebuilt. I thought I had solved my problem. No still the same problem ! I took it to a hydraulic repair shop and they found that the seals inside the small bedroom ram were leaking fluid past the seals. They rebuilt the small ram and now both slides work like when it was new.
Riverdude is online now   Reply With Quote
Old 10-31-2018, 08:49 AM   #8
Thumbs up Back in business
Well I have it fixed. I traced down all the wires on the pump and found a broken power wire to the solenoid. Also found out that there is no manual way to put the slide out, however there is a manual pump to slide it back in, in the event it was out and the pump didn't work.
Old 10-31-2018, 11:53 AM   #9
Head Rambler
Thanks for coming back and letting us know what you found.
I'm glad it was a inexpensive fix, even if it did cause you some time in locating it.
Gotta go campin!
Old 11-01-2018, 12:10 AM   #10
Good Deal, That is a lot easier than replacing the rams
slide
