Old 08-28-2016, 08:25 PM   #1
Slideouts
I purchased 2001 38' Sandpiper on a site this spring and I will need to be closing it up next month when the campground closes for winter.
The unit has two slide outs that operate by hydraulics and there is only one switch, two if you count the on the powerpack. Anyways only the front slideout moves when I activate the switch. I don't have a manual and so are not sure if the two slideouts should operate simultaneously or are they activated separately (in which case I need to find another switch).
Any help you can give me would be appreciated.
EricC is offline   Reply With Quote
Old 08-28-2016, 08:39 PM   #2
Cato's Avatar
slides
just trie to put slides in on our 2604ws
Neither will come in?
living area slide makes a noise
closet side nothing?
we need help too!
Cato is offline   Reply With Quote
Old 08-29-2016, 02:30 PM   #3
Head Rambler
EricC -- One slide usually operates first and the other one operates, all from the same switch. Did you let the one slideout complete it's travel to see if the other one moves afterward?
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-29-2016, 10:00 PM   #4
Slideout
No I didn't I just tested it briefly to see if it would mov.
I will give your suggestion a try next time I am at the trailer.
thanks
Old 08-30-2016, 07:54 AM   #5
Cato's Avatar
our issue was the battery cut off button...odd location right a floor level under refrig. must have been pushed in with vacuum?
Old 09-10-2016, 05:28 PM   #6
slideout not working/now working
The day before we were to leave on a one month trip, our main slideout on our 2016 Rockwood 8280ws stopped working. Checked fuses but still nothing.
We found the manual slide operation and decided to go ahead with our trip using our power drill to manually operate slide.
Every time we stopped for the night, we tried the button and still nothing.
Reached our destination four days later, and voila! the button worked and we have no idea why?
Anybody have any ideas why it would stop and then start again - short circuit in motor?
Husband checked for loose wires and non were evident from a visual.
MarieM is offline   Reply With Quote
slide, slide out
