Old 03-23-2018, 04:23 PM   #1
PT Crew Member - 10/2013
Slideouts dead. Help!
I have a 2015 Forest River 328RES. All 3 slideouts have quit working. No movement, no noise, no nothing. I'm connected to shore power and everything else appears to work. Where do I start to look to get them working again?
TIA
Pilgrim49 is offline   Reply With Quote
Old 03-23-2018, 04:43 PM   #2
grumpy0374's Avatar
Check your 12 volt house battery. If it's dead or low charge, slides won't work, even if plugged onto shore power.
Slide motors are 12 volt, and draw a lot of power when operated. If batteries are dead, slides will not work.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 03-23-2018, 04:51 PM   #3
clarkbre's Avatar
Two questions to help clarify:
1. Do the slideouts operate off of one or multiple switches?
2. If multiple, were more than one slide out being operated at the same time?
With no noise or indication of power, check your fuses on the DC side. It's likely a blown fuse that needs to be replaced. I stocked up and carry about 25 of them for our trailer...just in case.
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
clarkbre is offline   Reply With Quote
Old 03-23-2018, 05:29 PM   #4
That did it. Thank you. I had pushed in the switch to disconnect the batteries. Once I pulled it out the slideouts worked again. While my ignorance about such things I have learned to take for granted, what amazes me is I haven't inadvertently stumbled into this predicament previously in the years I've been dragging this beast around. Thanks again.
slide
