Old 07-13-2013, 12:36 PM   #11
Originally Posted by eisbell View Post
Thanks. What it is showing is the bedroom slide along the edge has these small bumps and a couple of them have tiny holes so something is punching up through the membrane.
Sorry I did not understand the issue, but herk came to the rescue, as he often does!
When they cut the plywood for this application, there is always one rough edge and one smooth one. Why wouldn't they put the smooth edge on top so this wouldn't happen? Or, better yet, quickly sand the edge?
Could it be that the factory simply doesn't care enough? Seems to be the case more often that not.
As for your spider cracks in the fibreglass, there could be something underneath pushing out. But quite often it just tends to do that. Unfortunately, there is no easy fix.
bakken is offline   Reply With Quote
Old 07-13-2013, 12:39 PM   #12
Further to herk's suggestion, I would first tap down all of the sharp wood splinters that are trying to poke through the rubber roofing, before you apply the eternabond. If left, they might work their way through the repair as well.
Old 07-13-2013, 12:40 PM   #13
eisbell's Avatar
Thanks again Herk but actually we have a 2013. We discovered this and dealer had to get it corrected with lien holder and I had to correct with insurance company.
eisbell is offline   Reply With Quote
Old 07-13-2013, 12:55 PM   #14
Herk7769's Avatar
Since you do not use a signature line with your truck and camper information in it (hint; hint); I was working off the information in your profile.
HAM CALLSIGN - KC3FFW
Old 07-13-2013, 12:58 PM   #15
eisbell's Avatar
I know we keep saying we need to go in and complete it. We will update with info.
Old 07-13-2013, 01:05 PM   #16
eisbell's Avatar
I can't change profile to 2013 Columbus 320RS and we drive a 2013 ford f250 king ranch
Old 08-11-2013, 08:54 PM   #17
Platokidd's Avatar
Here are two photos that I am talking about.
Eternabond Tape/ would also check the position of the slide-out to the opening.
In other words the slide could be out of adjustment. Rubbing too hard in that area.
Hard to tell from the pics but it looks like wipers or seal could be rubbing hard from the edge to few inches in. If the wood is rough in that area you might want to get it smooth out or it will continue to wear.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
R.I.P. Luke the campin dog
