Slides and Jacks Won't Work
Yesterday I parked my 2015 CC 36CKTS, disconnected, plugged in to my 50 amp service, and auto-leveled it. Jacks worked fine. It was raining hard and it was difficult to hear the sound of the slide pump. I pushed the slide button, and waited but the two main slides didn't move (the bedroom slide opens first) after about 5 seconds. I released the switch and realized that I was holding the "in" side of the switch. There is now a clicking coming from the switch next to the hydraulic pump when the slide switch is pressed and the jacks won't work either as they both run off of the same pump. I manually spun the hydraulic pump and it moved freely. I think I caused the issue by holding the switch the wrong way. The manual warns not to do this but doesn't say what the damage would be or what the fix may be. I have looked for a reset switch unsuccessfully. Any thoughts?
