Old 07-23-2016, 06:56 AM   #1
SemperFi3088's Avatar
Slides not working 2013 Georgetown
All fuses and breakers have been checked
We are at an RV Center and they can my figure out why the slides are not working.
Any ideas??
SemperFi3088 is offline   Reply With Quote
Old 07-23-2016, 07:41 AM   #2
SeaDog's Avatar
Being at the RV center like you said they can figure it out why are you asking for here? let us know what they find.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 07-23-2016, 07:48 AM   #3
nomad297's Avatar
I think the OP is saying the RV center can't figure it out. I used the Internet thesaurus.
Bruce
Old 07-23-2016, 08:15 AM   #4
SeaDog's Avatar
Thanks I had already hit the post button when I thought I wonder if he meant to say "Can't"
have not heard "internet thesaurus" good one.
Retired Navy
AF&AM of Idaho
Old 07-23-2016, 12:26 PM   #5
RudysWorld's Avatar
On mine there is a breaker under stairs in the battery compartment, did they check that?
Rudy - 10 year old long haired dachshund
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 07-23-2016, 12:52 PM   #6
Slide not working
We have a 2013 Georgetown 378. Have had the same problem. Under the steps in the battery compartment you will find two breakers. Do not go by looks only. Press the red button to trip the breaker, a red leaver will come out, press it back in. Do this for both breakers. Next you should see a small box that contains circuit board with fuses on it. On my unit the 15amp fuse, bottom row, far right controls the slides as well. Test this fuse , don't go by looks alone. This has solved our problems each time... Hope this helps.
Harvey
SCUBA Guy is offline   Reply With Quote
Old 07-23-2016, 01:20 PM   #7
Most of the time the stated repairs are accurate. There was an occasion where the switch on the wall panel failed. After pulling the panel out if the wall still connected, I took a picture of the terminals to insure accurate reinstall. After disconnecting one of the good switches and installing it in the place of the shorted switch the slide operated correctly. The switches are available from Amazon and the manufacture printed on the side of the bad switch. 2013 352xl
Dc8mdtmech is offline   Reply With Quote
Old 07-23-2016, 02:59 PM   #8
Retired Ford Tech
Obviously the Ignition is off, they won't work with the engine running or ignition on. Make sure you didn't turn the key all the way to accessories. Just a Thought.
rvpezzano is offline   Reply With Quote
2013, georgetown, slide, slide out
