Old 04-24-2013, 11:44 AM   #1
Cool Slidr Out Flex Guard
The over head lights on my front slide out quit working. When I inspected the wiring I found that the Flex Guard had broken and allowed the wiring to get pinched and short out. I was going to replace the Flex Guard on this slide out when I noticed that the rear slide out Flex Guard has broken also. What is the replacement for these (one that will actually work) and where do I get them?
Rogers81 is offline   Reply With Quote
Old 04-25-2013, 12:38 PM   #2
Dallas Texas
TexasBBQ's Avatar
i've seen them at camper and auto stores. Might need to find out why the broke first. Too short, wrong material?
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 04-25-2013, 12:47 PM   #3
Check to make sure it isn't getting pinched somewhere when moving the slide.
On our fifth, I found the wires to the fireplace were jammed against a very sharp piece of aluminum bracing, and they would have eventually rubbed through and shorted out like yours. But these were 120V wires, and it would have probably burnt the camper to the ground.
Don't trust the factory workmanship.
bakken is offline   Reply With Quote
Old 04-30-2013, 10:46 AM   #4
The carrier is designed wrong to much bending for the materiel it is made of. I do not want to replace it with the same thing just to have it break again!
Old 05-06-2013, 05:15 PM   #5
Angry closer look
I took a closer look this weekend. The flex guard is 48 inches long and the span it covers is 48 inches. The end that is supported by the rod on the outside of the slide workers great, but the end that is bolted to frame has no flex room. If it were 6-12 inches longer it would work.
Old 07-12-2014, 07:22 PM   #6
W4DNA
1 YO Rockwood - Broken Flex Guard
I guess I'll have to agree with Rogers81 - they aren't worth a flip! Picking up after an enjoyable 1 week vacation at a very nice, cozy campground and saw the wire/hose bundle hanging under my living room slide of our 8289WS. Further investigation noted the Flex Guard was broken at about the midpoint and at the fixed attachment point on the slide. Used some bungee cords to hold the bundle up for the 3 hour trip home. Plan on getting some aluminum piano hinge for the attachment point and for the mid point until I can find a better solution! (Noted no rubs or stress marking on the bundle or the camper...)
ID:	58031   Click image for larger version
ID:	58032   Click image for larger version
NCRadioman is offline   Reply With Quote
Old 07-12-2014, 11:22 PM   #7
tomjsas's Avatar
Yeah, mine has done the same. I used zip ties for a quick fix but need to figure out a permanent fix.
Tom
2004 Fleetwood Providence 38U
currently not towing a toad
tomjsas is offline   Reply With Quote
Old 08-10-2014, 03:04 PM   #8
W4DNA
Flex Guard Repair
Repairs complete. We'll see how they hold up. I'll post all photos to my albums.
ID:	60118   Click image for larger version
ID:	60119   Click image for larger version
ID:	60120   Click image for larger version
Old 11-09-2014, 12:58 AM   #9
Same problem. How has your repair been. Is there a better solution?
bigboyga is offline   Reply With Quote
Old 11-09-2014, 04:12 AM   #10
Witch Doctor's Avatar
Mine had the same problem nice repair job mine broke off at the end where it attaches to the wall.(your 2nd pic) I was lazy and attached a spring to it to hold it up. I think I might steal your idea...Thanks for posting that. By the way how did FR ever think that would hold up the way they installed it?
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-09-2014, 09:30 PM   #11
W4DNA
Repair's holding up very well. We've been out 4 times since and I've had the slide open several times as I've been making some minor mods - "personalizing" the 5'er. Probably will keep it as-is. Will see how it holds up in the colder weather. 1st year I've had it in the driveway all summer. Subdivision police usually hassle you... Not this year - maybe because I told them I'd go ahead and get legal and put it in the side yard... I think someone sold FR a bill of goods, there - I can't see that type plastic holding up to the flexing needed for this application...
Old 11-09-2014, 09:34 PM   #12
davel1971's Avatar
mine broke within 1st month of owning it. Both broke right where attached to frame. Reattached both sides with door hinges. Been working perfectly all year.
David & Lynn
