Old 08-17-2013, 01:28 PM   #1
Square Drive Shaft Bolt not Tight
One of the bolts that hold the square drive shaft on to the rear slide gear shaft is not tigntened all the way. (See photo on left). The one on the front slide gear apears ok. (See phot on right.)
My instincts tell me to tighten the screw, but then I checked the other side on our unit and found the exacts same situation...Rear not tightened , but front is...so now I'm not so sure.
Any comments would be apprciated.
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
SimchaSabre is offline   Reply With Quote
Old 08-17-2013, 02:03 PM   #2
Dave_Monica's Avatar
I don't think it matters as long as it's a self-locking nut. The bolt is a sacrificial shear pin to prevent damage to the drive should the slide-room jam.
Dave
Old 08-17-2013, 02:17 PM   #3
phat phrog stunt crew
doesnt look like a nyloc nut to my eyes.
dwaynerz is offline   Reply With Quote
Old 08-17-2013, 03:46 PM   #4
aka Windjammer2012
Crankshaft's Avatar
It is NOT a nyloc nut so the bolt could be a shear pin. I would put a wrench to it just to see if it would tighten easily. It doesn't look like there is a lock washer in place either so maybe the nut is working loose. Does the bolt which is tight have a lock washer? Come to think about this, it seems I have seen this before but don't remember where or when. If both of the slides are the same it may be the way it was intended.
Wayne & Vonnie
Layla (American Eskimo dog)
2012 Windjammer 3008W
2004 GMC 2500 HD CC Longbed
Crankshaft is offline   Reply With Quote
Old 08-17-2013, 04:44 PM   #5
I would replace all the nuts with nyloks and just snug them up.
Old 08-17-2013, 04:47 PM   #6
I just looked and they are lock nuts and they are just like the ones on the landing gear square drive. The bolt does not move back and forth thru the gear shat hole, but if it is like the one on the landing gear, that hole is threaded.
Another observation is that on both slides, the nut that is not completely tigned in on the motor end of the shaft. I'm not sure what that means, but it is interesting.
Maybe the LCI guy that I met at the Goshen FROG Rally is learking on the forum. He mentioned to me that he intends to start doing that.
Cathy & Jeff
Midland, Michigan
Old 08-17-2013, 04:52 PM   #7
The nuts don't have to be tight, they just have to have the nylok engaged, they are just shear bolts.
Old 08-17-2013, 04:56 PM   #8
That's what I'm inclined to do. I can't think of any mechanical reason for leaving that space...even if it is a lock nut.
Thank OC
Cathy & Jeff
Midland, Michigan
