Old 01-07-2016, 03:04 PM   #1
Stabilizing slide
What would be the best location for stabilizers (Stack jacks probably) under any of the slides? It is hard to tell what is the frame and what is not. How about the actual slide arm? I would think as long as you support it on a flat and nowhere near any of the drive teeth it should be OK.
Thoughts?
2016 Rockwood Signature Ultra Lite 8329SS
2004 Dodge Ram 3500 (Sterling) Auto w/built trans, 4X4 Quad Cab 5.9L Cummins
mikemc53 is offline   Reply With Quote
Old 01-07-2016, 03:06 PM   #2
Do not put stabilizer jacks under slides. Lots of posts on here describing the damage it can cause.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2 - 2006 model year Border Collies
Mtelkman is offline   Reply With Quote
Old 01-07-2016, 03:41 PM   #3
TURBS's Avatar
Run fast from this idea !
Do not look back!
Sent from my SM-G900R4 using Tapatalk
Old 01-07-2016, 04:03 PM   #4
Thoughts?
The best place is Back in the Box they came in! Youroo!!
Old 01-07-2016, 04:04 PM   #5
Might I ask why you want to stabilize the slide?
They are built to handle the weight of the slide and the components/people inside without the need for support.
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 01-07-2016, 04:46 PM   #6
bikendan's Avatar
Using such things will void the warranty.
Modern slideout shouldn't need such things.
Old tech slides did.
Equalizer WDH
Old 01-08-2016, 04:46 AM   #7
Thanks gang. It is obvious that this is not a necessary or viable approach. The only reason I asked was that I had a neighbor show me an add from Camping World where they were selling slide jacks/stabilizers and I thought they were quite pricey so was looking at alternatives. I also noticed that where we are currently set-up (at a place with almost 500 sites) I have only seen 2 units that have any type of stabilization under their slides. That alone (only 2 of 500) should have told me something.
slide
