Old 03-13-2019, 09:26 AM   #1
Storing in Open with Slides Out
I have seen several trailers being stored for the winter in areas with heavy snow fall that leave their slides out. Seriously, can the added weight of snow on those slides be good for the unit? We have always stored ours with the slides in, even under a covered storage. When I say heavy snow, not meaning just a skiff, but 4-8 ft of heavy, wet snow.
ijensen is offline   Reply With Quote
Old 03-13-2019, 09:45 AM   #2
I'd never store my TT with the slides out...period.
TheWolfPaq82 is online now   Reply With Quote
Old 03-13-2019, 10:44 AM   #3
If you are talking in a storage lot, that would be pretty unusual anywhere, snow or not.
If you are talking about being on a dealer's lot, that may make some sense as they still have people walking through them.
There is always the possibility of water damage although I've seen pictures of workers standing on slides as well. So I think some can handle the weight.
Iwritecode is offline   Reply With Quote
Old 03-13-2019, 10:56 AM   #4
If you can stand in them you should be able to stand on them . i get on mine as needed though i don't stand , hands and knees only
MR.M is online now   Reply With Quote
Old 03-13-2019, 01:07 PM   #5
KMANUEL74's Avatar
I would think the floor of a slide can support more weight than a roof of a slide
But either way, I always store with mine closed.
KMANUEL74 is online now   Reply With Quote
Old 03-13-2019, 01:21 PM   #6
Roof of a slide is just as solid and just as think as the floor . not like the roof with 1//8 luan
Old 03-13-2019, 08:25 PM   #7
24/7/365
Our slides are out 24/7/365. I don't even know if the hydraulic system works. And the stabilizer jacks under the slides would have to be removed.
The roof on each slide is 15/32" plywood over 2 x 2 joists. Quite solid when I walk on it. No leaks, either.
We don't get too much snow in southeastern Virginia, but it's had at least 6" of wet and sloppy.
Larry
Larry-NC is offline   Reply With Quote
Old 03-14-2019, 12:00 PM   #8
They should be anyway.
Old 03-14-2019, 12:24 PM   #9
Never, Never, NEVER store for any extended period with the slides out. Snow or no snow. Too many crevasses for critters to get in, slide seals deteriorate more quickly from UV exposure, water leak potential in storms, not to mention any snow loads if you're in a cold climate. I could go on and on....
2corvette is offline   Reply With Quote
Old 03-14-2019, 12:55 PM   #10
They've been there for years.
They've been there for years. I check them periodically to make sure the slides are square with the trailer, neither sagging nor lifted.
Larry
slide
