Old 09-14-2015, 08:45 PM   #1
parkerbob
Sunseeker 2006 3100SS Slideout Broken
Hi,
When it worked, we had to allow it to pop a few times to make sure it was either fully open or closed. Now it quit working and was very difficult to push back in.
The trouble has been traced (perhaps) to the differential where the axils come out of, please see photo. The motor and gear boxes work fine, and the manual drive turns, but not the axils.
Anybody ever experience repairing something like this? Since it is an above-floor slideout, there seems to be no access to the two gears on their rack & pinion design. That little place in the storage compartment seems to be the best that I can find. Now, I'm trying to take the differential off and that is no easy task. Is it possible that the axils are inside a tube, so that one cannot see them turn anyway?
Name:	IMG_2651 transfer case with cover removed.jpg
ID:	88706   Click image for larger version
Name:	IMG_2652 transfer case for manual drive.jpg
ID:	88707   Click image for larger version
Name:	IMG_2672 both shafts from gearbox.jpg
ID:	88708   Click image for larger version
Name:	IMG_2688 motor and gear box removed.jpg
ID:	88709   Click image for larger version
Name:	IMG_2690 differential with axils.jpg
parkerbob is offline   Reply With Quote
sunseeker, 3100ss, slide, slide out
