Hi,
My slide out kitchen is crooked on left hand side looking from inside.
Here is the diagnostic from the technician : floor is collapsing below slide out.cause unknown. Will have to take the slide out to find out why. Could be due to foam floor letting go.
Here is the correction : remove slide out and repair floor to resupport slide out mechanism wich has collapsed. Minimum : 35+ Hours.
The extended warranty does not cover this problem. I don't know why???
I want you're opinion and suggestion ? Do you see this problem before ? And why is not covered by my extended warranty, i have the big ultimate plan...
Also, i attached a picture of stress cracked than i find outside in the bottom of the same slide out.
Is not a old motorhome. 2013 with 24 000 miles. For me this situation is fully anormal.
Thanks !!!!
