Old 06-02-2011, 07:18 PM   #1
Sunseeker 3120 DS Front Slide Fuses
I have a 2011 Sunseeker 3120 DS. The front slide does absolutely nothing when the switch is engaged, so my thought is that it blew a fuse. Tracked down the fuse box to under the bed but none of the fuses there are labeled for the front slide. The bed slide fuse is labeled. Anyone know where the fuse for the front slide is?
The fuses are supposed to light up when they are blown but do I have to engage the switch and look at the fuse box?
Thanks.
RogerCaiazza is offline   Reply With Quote
Old 06-02-2011, 07:37 PM   #2
My 3170 ds has fuses in a panel at the bottom of the stairs at the side door. When I had issue with main slide we found the fuse there.
Tbeasley77 is offline   Reply With Quote
Old 06-02-2011, 07:54 PM   #3
Thank you. Did that fuse panel have a bunch of empty fuse slots? I looked at that but I could not figure out what they were for.
Old 06-02-2011, 08:00 PM   #4
Yes there are some empty slots. Mine has a diagram on the door you remove. Also in mine they are the longer fuses.
Old 06-03-2011, 06:38 PM   #5
I changed the fuse and still nothing. Anyone have any other suggestions?
fuse, slide, sunseeker
