Old 06-27-2019, 07:57 PM   #1
Sunseeker Slideout only works if engine running
I recently purchased a 2019 Sunseeker 2250LS built on a Chevy 4500 chassis. We are currently using it for the first time and have found that the slideout only works if the engine is running. We are connected to 120V/30A shore power but the slider does not work with either that or when plugged into the generator.
This does not seem correct. While the owner's manual recommends that the engine is running when extending/retracting the slider, it seems like potentially a big problem if it can only work when the engine is running. There also does not seem to be any way to manually extend or retract the slider.
I would appreciate your input/experience. Nobody I have talked to has this kind of limitation.
Rossnet is offline   Reply With Quote
Old 06-27-2019, 08:33 PM   #2
Lame *****
Have you called the dealer and ask a tech about it?
Maggot
Maggot is offline   Reply With Quote
Old 06-27-2019, 08:43 PM   #3
Maggot
Thanks Maggot, no, we are currently on our maiden voyage and will be returning home tomorrow but will certainly call the dealer when we return.
Old 06-27-2019, 08:48 PM   #4
Lame *****
If you can maybe call before you pull out. They may have some ideas or say stop by on your way home if you can?
Maggot
Old 06-28-2019, 09:00 AM   #5
Commercial Member
ES_FR's Avatar
Rossnet,
Thank you for being a part of the Sunseeker family.
Please accept our sincerest apologies for any inconveniences that you have experienced with your new Sunseeker. Your satisfaction is very important to us; accordingly, we invite you to contact Josh Cavitt in our Customer service department through the following personalized and direct link: Forest River RV Direct Service Contact - Forest River, Inc..
This direct link is provided for your convenience in order that we may resolve your concerns as quickly as possible. We will strive to respond to you within 24 hours of receiving your correspondence.
Respectfully,
Forest River
ES_FR is offline   Reply With Quote
Old 06-28-2019, 01:02 PM   #6
I just purchased a 2020 Forest River Forester 3011DS on the Ford E-450 chassis and discovered not only that the engine had to be running to operate the slides but also to operate the leveling jacks and even the awning even when plugged into shore power! This seems really stupid to me, especially for the awning. We went camping for the first time a couple of weeks ago and were in a fairly crowded campground. We had close neighbors on both sides. We were sitting quietly outside and just after midnight it got really windy. I had to fire up the engine to retract the awning. On top of that, the awning control is on the monitor pad near the back of the unit where you cannot see the awning. I had to have my better half standing outside and yelling at me when the awning was fully retracted. There was no other way to tell. The neighbours were rightfully annoyed! What a dumb design. I cannot see the logic behind it. Makes you wonder if the designers have ever actually used the units they design. I spoke to my dealer and he asked me to bring it in so he can see if there is a way to rewire it with a switch by the door and to operate without having to fire up the engine.
HYDROG is offline   Reply With Quote
Old 06-28-2019, 01:09 PM   #7
DaGrinch's Avatar
Wow, how things have changed! While I don't have any suggestions for either of you, my 2017 Sunseeker 3010DS has to be OFF for the Bigfoot leveling jacks to work or I get a warning buzzer. Seems strange the slide won't work while on shore power.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 06-28-2019, 01:57 PM   #8
sunseeker 3010DS
I don't know, but I have opened the slides on battery and on shore power, which is battery added, but I do have to have the e-brake and motor running to operate the leveling system. I think I will keep the address as I also just purchased a 2018 3010ds sunseeker.
SQROOT is offline   Reply With Quote
Old 06-28-2019, 02:41 PM   #9
On my 2019 3011 dsf the engine must be running for the jacks and slides and awning to operate, was told this at the pdi, also had warning labels on the one control. I have operated the awning with the key in the on position, and the engine not running.
Badabbotts is offline   Reply With Quote
Old 06-28-2019, 03:04 PM   #10
We have a 2017 Sunseeker which since we bought we have had a problem with drain holes under slide and under slide wall leaking. We are on our 4th visit at dealership.
Each time they reseal the seals on the outside. This past time they sealed lower drain pan in the corner of slide opening and cut bulb seal to allow water to get out. We still have a leak under the couch through a drain hole. A hole that drains into the coach does not make sense to me and of course it still leaks but only when the weather is heavy rain.
They now want to take out the slide which I know this will be a big bill. They have covered all the other visits but come on.... This is not covered by the extended warranty since this is a used RV when we bought. I have just now texted the Forest River contact. Has anyone else had this type of problem?
Allen Page is offline   Reply With Quote
slide, sunseeker
