Hello, and
to the forums. I moved this thread to general repair. Now to answer your question, start at the battery, and trace the positive cable. Should find withing 5 feet of wire, one, two or more breakers, with a small reset button on one end. Probably one of them tripped, maybe, but it it the first place to look. Also may try a search on here for things like "slide doesn't work", you'll see it is a very common problem, and may find pictures of various breakers and things used over the years. If that is a small wire feeding the switch, 14 gauge or so, there is a relay in the system somewhere also. Don't have a wiring diagram, and you will not find one most likely, but good luck.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
