Old 03-29-2016, 10:01 PM   #1
MarkyB's Avatar
This can't be good.
I noticed this today while mowing.
Not sure what these are called, I know it's some kind of adjuster.
The ones on the other slides seem to be tightened.
Is this something I can fix myself or do I need to call the dealer?
16 F-250 Lariat 6.2 -- 16 Wildwood 31KQBTS
Nights Camped in 2016 : 25
Nights Camped in 2017 : 20
MarkyB is offline   Reply With Quote
Old 03-29-2016, 10:13 PM   #2
Somebody forgot to tighten up the "jam Nuts"! Youroo!!
Old 03-29-2016, 10:16 PM   #3
northstar1960's Avatar
those do adjust the slide , threading them up if i remember correctly will pull, the top part of the slide in further,down will pull the bottom in further . there are other bolts that need to be loosened to do the adjustments ,looks like they have held things in place if so just snug the adjuster bolt back up . as long as your slide closes evenly your good to go
northstar1960 is offline   Reply With Quote
Old 03-30-2016, 07:12 AM   #4
MarkyB's Avatar
Ok thanks!
