Old 12-27-2011, 10:45 PM   #1
fast murray's Avatar
Tilted Slideout
Our slideout is tilted out on the bottom. When looking back in the mirror it gives the impression that one of the storage doors is open. It seems to work properly and to my knowledge does not leak. Is there a way to adjust it or a reason not to? We don't have a local dealer to take it to but I can usually fix most things.
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 12-27-2011, 11:00 PM   #2
How much is it tilted out?
Is there a gap between the seal and the side of the camper?
Old 12-27-2011, 11:12 PM   #3
It's pretty much flush on the top and out 1 1/2" on the bottom. The seals aren't touching starting at about half way down from the top.
2004 Wildcat 28BH
Old 12-28-2011, 07:37 AM   #4
It simply isn't being pulled all the way into travel position. When it gets that far, do you get that ratcheting sound from the drive slipping, or does the drive just stop? (it is electric, I assume?)
Old 12-28-2011, 12:14 PM   #5
Anacortesians
I understand that the slides are specifically rigged to go in slightly further at the top, to ensure the top seals are tight, to keep rain out, but 1.5" seems excessive.
On our GT325, I would estimate the slide-out walls are maybe 1/4" out at the bottom when the drive starts to slip. The bulb seals are compressed, but not completely flat. When the slides start to go out, the top moves first, then the whole thing ends up with the outside wall vertical and all the inside bulb seals equally compressed.
Frank and Eileen
No longer RVers or FR owners
Old 12-28-2011, 07:06 PM   #6
I've never heard the ratcheting sound. I push the in button until it stops and I think you can hear the motor bog like the cylinder is at the end of it's travel.
Here's some pics:
2004 Wildcat 28BH
Old 12-28-2011, 08:42 PM   #7
That is definitely not the way it is supposed to be.
I don't know how it could happen, but check the bell stop on the power ram under the slide. Something is definitely stopping the slide from going all the way in.
Old 12-28-2011, 09:08 PM   #8
Looking at a bunch of trailers where I store mine, all are flush except mine. Haven't seen mine for about a month, but mine lacks about 3/4 to 1 inch from closing on the bottom if I remember correctly. But then with the way its designed, it could never close more than another 1/4 inch. (P. S. It's a Flagstaff). Wayne
wayne anthony is offline   Reply With Quote
Old 12-28-2011, 09:36 PM   #9
I'm not sure it was this bad when I put it away, is it possible for them to settle that way as they sit for a while? My loader settles but it has gravity working against it. This weekend I think I'll put the battery in it and check it out. Supposed to be in the 50s in South Dakota!!
2004 Wildcat 28BH
Old 01-03-2012, 10:40 PM   #10
Alright, so I set the battery in it and hit the in button any it went in. WOW!! So, if you want your slide to look like it's not in all the way, just leave it out a little Thanks everyone!!
2004 Wildcat 28BH
Old 01-07-2012, 08:05 AM   #11
What was the culprit not completely retracted before removing the battery?
2012 Rockwood 8314BSS
2011 Chevy
Camping, Dutch Oven Cooking, and Homebrewing
campdohbrew is offline   Reply With Quote
Old 01-08-2012, 10:21 PM   #12
I'm guessing so, I'll keep an eye on it to see if it falls our a little over time. From the time we bought it last summer we used it really steady and it was being cycled in and out alot so I didn't notice. It's really easy to tell when it's there so I can't imagine not doing that but time will tell.
2004 Wildcat 28BH
Old 01-29-2012, 02:27 PM   #13
Update: It's been a little less than a month since I checked the slide and it's starting to hang out a little on the bottom. What would cause it to do this? The hydraulic cylinder leting it settle?
2004 Wildcat 28BH
