Old 05-21-2013, 07:58 PM   #1
Tracer 3150bh fuse or circuit for slide outs
Good evening all, I recently purchased a tracer 3150. Had some very heavy rains as I was charging battery and cleaning up inside. Now both slides not work plus the front power stabilizer jacks. I'm assuming I blew a main fuse or breaker. All of them are fine where the power converter is located. Where is the breaker or fuses that run the slides or jacks? Just can't seem to locate... There is a little black box mounted by the A frame, but I just see a whole lot of wires terminated with each other. Crawled under camper and can't find. Any help would be so greatly appreciated! Very grateful for advice. Thanks, Hans from MN
Hsiefker is offline   Reply With Quote
Old 05-21-2013, 08:02 PM   #2
TURBS's Avatar
There are or could be resetable circuit breakers up by the battery or close to it.
They may be in box but normally they are mounted to the frame.
You may also find a fuse up in there!
Turbs
Old 05-21-2013, 08:07 PM   #3
Thanks Turbs. I found a small 1.5 x 2" box that was connected ( I thought) to the emergency brake wire. I will double check that shortly. Dumb question, but what does the breaker look like? I know what a breaker in a panel in a house is, but how big or size will this be?
Thanks again.
Old 05-21-2013, 08:15 PM   #4
TURBS's Avatar
Something of this sort.
It may or may not be resetable.
Take your multimeter with you to check voltage.
If you don't have one its time to invest in one and keep it in the camper.
Black button is reset.
Old 05-21-2013, 08:30 PM   #5
I found a 3 x 7 plastic box and took the cover off and it has lots of wires terminated inside. I will look closer tomorrow when I get home from work. I didn't see anything like the pic you sent, but I will take a closer look.
Thanks again.
