Old 10-12-2014, 10:52 AM   #1
Trouble with slide
Hello,
We have a Forest River Sierra 27RKSS with one slide out. We've never had any problems with it. Yesterday, after we got done winterizing, we activated the switch to bring in the slide, it sound normal for about 3 seconds, and then started clicking. WE tried a couple more times and the same thing.
Appreciate any assistance. Thank you, Dan
dpmehlhoff is offline   Reply With Quote
Old 10-12-2014, 11:35 AM   #2
Jerry01's Avatar
My first thought would be electrical. We had this problem on our last trailer. I cleaned all of the connections, including the ones on the slide out pump itself, then everything worked again. I'm assuming that the batteries are charged? Jerry.
2005 GMC Sierra 2500HD, Duramax 2WD CC/SB
2013 Cardinal 3030RS full body paint
B&W Companion slider, air bags, EFI Live Custom tuning by So Cal Diesel
Jerry01 is offline   Reply With Quote
Old 10-13-2014, 12:28 PM   #3
Thanks Jerry for the response. Today I manually brought the slide in and yes the battery is definitely dead. I assume I need a new battery or is there another reason why the battery didn't charge while the trailer was plugged in?
Again, thanks for your assistance, Dan
Old 10-13-2014, 03:44 PM   #4
Jerry01's Avatar
The battery could be bad if it did not charge while plugged in. Or it could be a blown fuse possibly. If you have a multi meter, next time you plug it in, check for voltage at the battery. It should read approximately 14 V while charging. Jerry.
slide
