Old 06-11-2015, 02:32 PM   #1
Ugly colored swimming noodles or
What options are there to put on the bottom edge of slideouts to prevent head knocks or cuts. We currently use swimming noodles with a notch in them to fit. I see Camping World offers a corner guard that is applied with adhesive. It does not cover much of the edge and may not allow slide to snug up tight to camper when closed. Any hints would be appreciated.
Nana Suey is offline   Reply With Quote
Old 06-11-2015, 02:34 PM   #2
Old car's Avatar
I've hit mine so many times I think I'm shorter now. Or just learned the hard way. I believe noodles are the most common quick fix.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 06-11-2015, 02:46 PM   #3
Sharon455's Avatar
We use the foam pipe covers from Ace Hardware. They already have a slit down one side, are usually a dark gray or taupe color. They come in different dimensions, but the ones we have are about 2" in diameter with a 1" "hole" where the pipe goes.
Bonus ... can be used to cover hoses if camping in the wintertime.
Happiness is just a ride away!
Sharon455 is offline   Reply With Quote
Old 06-11-2015, 03:00 PM   #4
67cudafb's Avatar
Get something like this. Safety Flag 3 in. x 1,000 ft. Caution Barricade Tape-CBT3 - The Home Depot and a couple clothes pins. Hang a 2 foot piece from each corner of the slide so it is noticed before you bonk your head.
1967 Barracuda fastback
2015 Wildcat MK 333
2010 Ram 2500 Mega-cab
67cudafb is offline   Reply With Quote
Old 06-12-2015, 12:46 PM   #5
jackdn0610's Avatar
The biggest culprit in my case are the corners of the slideouts. I use tennis balls sliced open and place on each corner. No big ugly noodle that way.
Jack & Jo Neihouse
Grass Valley, CA
2014 Cardinal 3450RL
2011 Ford F350 SD DRW
F.R.O.G. Members
jackdn0610 is offline   Reply With Quote
Old 06-12-2015, 01:07 PM   #6
milvet33's Avatar
Slide out corners
I was working on my RV and walked around the rear end deep in thought not knowing that my wife put the bedroom slide out. Caught me right at the hairline. Emergency room used staples to close the gap (I suggested Super Glue but they nixed that idea). I counted 10 staples going in (they all hurt because the got mixed up and didn't show up with the shot to deaden the area until the task was done). The doc reloaded the gun and continued stapling. Final staple count was 16 (I counted them when they removed them). I installed the Camping World ones and they work fine, don't fall off and don't impact on the slide out closing. I bang my head all the time ducking under that slide out but no more staples required. BTW I also installed some under counter top corners so I don't have to get our dogs stapled back together.
milvet33 is offline   Reply With Quote
Old 06-12-2015, 01:31 PM   #7
I put solar light sticks like the they use on lawns I put them in old cottage cheese containers filled with gravel. I place them on the ground at all four corners of the RV and by the slide outs even at night they keep you out of harms way.
edcronin01 is offline   Reply With Quote
Old 06-12-2015, 02:17 PM   #8
justwinginit's Avatar
Great idea will tell hubby
justwinginit is offline   Reply With Quote
Old 06-12-2015, 02:26 PM   #9
Oakman's Avatar
Wouldn't work for me. I'd end up tripping over or kicking the cheese containers and then bump my head. Swim noodles are the way to go for me.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 06-12-2015, 02:40 PM   #10
dan-nickie's Avatar
Originally Posted by milvet33 View Post
The doc reloaded the gun and continued stapling. Final staple count was 16. I installed the Camping World ones
You used the Camping World Staples on your head?
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 06-12-2015, 02:58 PM   #11
caper's Avatar
Buy a bump cap. They look like a baseball cap but have a hard plastic liner more stylish then a hard had and will keep your head safe.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 06-15-2015, 09:04 AM   #12
The head hurts
the issue of slides and heads has been going around for some time now, I have used the rubber corner guards for years and they have always worked great. If you feel that the whole edge is not protected they the only way is to use a pool noodle. I also look at the idea of hit and learn from hard knocks, you need to LEARN where the slide is.
Happy Camping
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 06-17-2015, 05:26 PM   #13
I owe it all to bacon.
Eklc's Avatar
Never had a problem with slides, I just walk into the awning supports. At least twice a year....
Eklc is offline   Reply With Quote
Old 07-21-2015, 12:24 PM   #14
D LBRS's Avatar
The bright-colored swimming noodles are ugly, but after I hit my head the first time I grabbed the closest one available and made some corner protectors. They are lime green. I'll probably make new ones if I ever come across a white or black noodle. The DW tells me I always walk with such purpose (like I've got somewhere to go)....I swear, when I hit that corner with my forehead I had to fight back the darkness!
D LBRS is offline   Reply With Quote
Old 07-21-2015, 01:55 PM   #15
Jim Schings's Avatar
As the owner of a race car prep shop, we have what we call "Non SFI Roll Bar Padding" in lots of colors. Similar to the foam pipe insulators, but a little harder and oblong (thicker on one side). They also have a split that you cut on one side. They come in every color of the rainbow, but I PREFER the YELLOW. I don't care if they are ugly. I want to SEE them...
They stay in place with no problems. I also like them to overlap the ends a bit so no "hit" cuts the head open....
Jim Schings is offline   Reply With Quote
Old 07-21-2015, 02:16 PM   #16
KennyGolub's Avatar
I don't think so. If CW staples were used, he wouldn't be here to tell the story. Would have bled to death waiting on the shipping..........
Ken & Laurie
2022 Riverstone Legacy 39RKFB
2022 RAM 3500 Laramie Dually
KennyGolub is offline   Reply With Quote
Old 07-21-2015, 02:31 PM   #17
Made me laugh out loud - thanks!
Brian, Stacy, and the kids
2011 F-250 CCSB 6.7L PSD 4WD
2013 Palomino Solaire 269BHDSK
ProPride Hitch
purduepete97 is offline   Reply With Quote
