Old 07-20-2016, 12:52 PM   #11
JustB_Rad's Avatar
The gutter on both sides of the unit is two pieces with caulk in the seam. The caulk on ours was just gooped on...making a dam in our gutter towards the "low" side. Even when level, you're always low in one corner or another. I noticed it leaking through on my awning side....check it out on yours. Betcha that's the problem.
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
(2014) Nights Camped - 16 in 6 trips (2015) Nights Camped - 20 in 6 trips
(2016) Nights Camped - 21 in 7 trips
(2017)16 Night Booked in 4 Trips - 6 in 2 more Trips Planned
JustB_Rad is offline   Reply With Quote
Old 07-20-2016, 12:53 PM   #12
DAISY BOYKIN's Avatar
Water on slide out
If you suspect water is on the roof of slide out, before hooking to your tow
vehicle raise the front of your unit with the front jack or landing gear about six inches higher than the rear. The will cause the water to run off the back of your slide out before closing the slide out. I have slide out awnings
but sometimes the water will pool on the largest slide out, this is how I remove the water sometimes.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
BOLIY PRO 3600SI GEN
DAYS CAMPED 2016 74 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 07-20-2016, 01:51 PM   #13
oldsmasma's Avatar
So agree that slide toppers are the way to go. No more leaves, pine needles or water.
Phil, Heather & Olaf the Boxer
Ontario Canada
Lexington 283GTS
nights camped 2015-89
2016 - 31
oldsmasma is offline   Reply With Quote
Old 07-20-2016, 02:01 PM   #14
Retired Retail/Importer
I was told that the slide covers make the rv hotter! True?
pledbetter is offline   Reply With Quote
Old 07-20-2016, 02:06 PM   #15
oldsmasma's Avatar
This is our first rv with them but I don't see how they would make it hotter. I don't see any temperature difference. Then again I do not live in the south.
Ontario Canada
Lexington 283GTS
2016 - 31
Old 07-20-2016, 02:07 PM   #16
Moderators' Assistant
bikendan's Avatar
Nope
Dan-Retired Firefighter/EMT
2016 PrimeTime TracerAIR 255, pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 07-20-2016, 02:18 PM   #17
The slide seals do not always get all the water off the slide roof. Some amount of water is generally normal.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 07-20-2016, 03:02 PM   #18
CaptnJohn's Avatar
Not at all, light colored toppers here so if anything reflect heat.
My theory is 'old bones take longer to heal' so we are not climbing ladders any longer. Using a broom or blower is no longer even considered. The toppers keep the slide from accumulating water, leaves, twigs, and etc. Even young bones do not heal overnight.
2016 Keystone Cougar 303RLS
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 07-20-2016, 03:31 PM   #19
Ret E-9 Anchor-clanker
donanddona's Avatar
You should have some type of squeegee/seal at the top. Although probably not adjustable, most slides have jacking screws to raise sliders. Visual verification of your top seal is a must before attempting any adjustments.
donanddona is offline   Reply With Quote
Old 07-20-2016, 03:34 PM   #20
donanddona's Avatar
I often put a slight risee in the RV. This may also be helpful to you.
slide, slide out, water
