07-19-2016, 12:51 PM
Water Staying on slide out when retracting
Silly question
We were dry all weekend however AC runoff was dripping onto slide. Didn't think much of it so when we packed up to go we brought slide in and alot of water stayed on slide and splashed all over inside unit. I'm curious is this normal or should seals act as a squeegee and push water off slide when bringing the slide back in ?
07-19-2016, 02:03 PM
Originally Posted by Zero1zw
Silly question
Do you have gutters on your trailer? They should catch most of the water.
07-19-2016, 05:06 PM
Yes they do have gutters
The trailer is brand new 2017 Cherokee 26 DBH
07-19-2016, 06:40 PM
This happens to us occasionally but NOT from the a/c. The gutter should route the a/c runoff to a spout, NOT your slideout roof. I would check the gutters first.
When it rains we get water on the slides and no, the seals don't take off all the water. At least not on any rig I have ever had. So we either raise/lower the front until the water runs off, or I get up there and sweep it off with a broom. Otherwise you will get a bath when you button things up
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
07-19-2016, 07:39 PM
The rain gutter spout on the front driver side directs the water to the top of the bedroom slide! Nice design. We do have slide covers so the slide top is dry when we pull it in.
Tom & Renée
Durham, NC
2021 Jayco Class C model 27U
07-19-2016, 07:48 PM
Even with gutters I get a little water on the slides, I always sweep our slides before pulling them in.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
07-19-2016, 08:25 PM
Our ac water drains out the gutters so not an issue but yes rainwater is an issue when pulling in the slides.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
07-19-2016, 08:32 PM
With Slide Toppers we have no water on the slide at all. Second trailer with slide toppers and I highly recommend them.
B and B
07-19-2016, 10:49 PM
Gutter had a small leak in it. We have had some slide issues with water previously so just wanted to make sure this was "normal ".
07-20-2016, 12:45 PM
x2 on the slide topper.
07-20-2016, 12:52 PM
The gutter on both sides of the unit is two pieces with caulk in the seam. The caulk on ours was just gooped on...making a dam in our gutter towards the "low" side. Even when level, you're always low in one corner or another. I noticed it leaking through on my awning side....check it out on yours. Betcha that's the problem.
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
Nights Camped - (2014) - 16 in 6 trips (2015) - 20 in 6 trips
(2016) - 21 in 7 trips
(2017) - 12 in 3 and going seasonal for at least the rest of the year!
07-20-2016, 12:53 PM
Water on slide out
If you suspect water is on the roof of slide out, before hooking to your tow
vehicle raise the front of your unit with the front jack or landing gear about six inches higher than the rear. The will cause the water to run off the back of your slide out before closing the slide out. I have slide out awnings
but sometimes the water will pool on the largest slide out, this is how I remove the water sometimes.
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
07-20-2016, 01:51 PM
So agree that slide toppers are the way to go. No more leaves, pine needles or water.
Phil, Heather & Olaf the Boxer
Ontario Canada
Lexington 283GTS
07-20-2016, 02:01 PM
Retired Retail/Importer
I was told that the slide covers make the rv hotter! True?
07-20-2016, 02:06 PM
This is our first rv with them but I don't see how they would make it hotter. I don't see any temperature difference. Then again I do not live in the south.
Ontario Canada
Lexington 283GTS
07-20-2016, 02:07 PM
Nope
07-20-2016, 02:18 PM
The slide seals do not always get all the water off the slide roof. Some amount of water is generally normal.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
07-20-2016, 03:02 PM
Not at all, light colored toppers here so if anything reflect heat.
My theory is 'old bones take longer to heal' so we are not climbing ladders any longer. Using a broom or blower is no longer even considered. The toppers keep the slide from accumulating water, leaves, twigs, and etc. Even young bones do not heal overnight.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
07-20-2016, 03:31 PM
Ret E-9 Anchor-clanker
You should have some type of squeegee/seal at the top. Although probably not adjustable, most slides have jacking screws to raise sliders. Visual verification of your top seal is a must before attempting any adjustments.
07-20-2016, 03:34 PM
I often put a slight risee in the RV. This may also be helpful to you.
