Old 07-19-2016, 12:51 PM   #1
Zero1zw's Avatar
Water Staying on slide out when retracting
Silly question
We were dry all weekend however AC runoff was dripping onto slide. Didn't think much of it so when we packed up to go we brought slide in and alot of water stayed on slide and splashed all over inside unit. I'm curious is this normal or should seals act as a squeegee and push water off slide when bringing the slide back in ?
Zero1zw is offline   Reply With Quote
Old 07-19-2016, 02:03 PM   #2
Originally Posted by Zero1zw View Post
Silly question
Do you have gutters on your trailer? They should catch most of the water.
Iwritecode is online now   Reply With Quote
Old 07-19-2016, 05:06 PM   #3
Zero1zw's Avatar
Yes they do have gutters
The trailer is brand new 2017 Cherokee 26 DBH
Old 07-19-2016, 06:40 PM   #4
NMWildcat's Avatar
This happens to us occasionally but NOT from the a/c. The gutter should route the a/c runoff to a spout, NOT your slideout roof. I would check the gutters first.
When it rains we get water on the slides and no, the seals don't take off all the water. At least not on any rig I have ever had. So we either raise/lower the front until the water runs off, or I get up there and sweep it off with a broom. Otherwise you will get a bath when you button things up
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 07-19-2016, 07:39 PM   #5
5er_tom's Avatar
The rain gutter spout on the front driver side directs the water to the top of the bedroom slide! Nice design. We do have slide covers so the slide top is dry when we pull it in.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2012 Ford F-250, 4x4, 6.7 Liter Diesel
5er_tom is online now   Reply With Quote
Old 07-19-2016, 07:48 PM   #6
Crusadernoob's Avatar
Even with gutters I get a little water on the slides, I always sweep our slides before pulling them in.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!
Nights camped in 2014 37
Nights camped in 2015 40
Nights camped in 2016 39
nights camped in 2017 7
Crusadernoob is offline   Reply With Quote
Old 07-19-2016, 08:25 PM   #7
Canadiancrew's Avatar
Our ac water drains out the gutters so not an issue but yes rainwater is an issue when pulling in the slides.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
Canadiancrew is offline   Reply With Quote
Old 07-19-2016, 08:32 PM   #8
B and B's Avatar
With Slide Toppers we have no water on the slide at all. Second trailer with slide toppers and I highly recommend them.
Old 07-19-2016, 10:49 PM   #9
Zero1zw's Avatar
Gutter had a small leak in it. We have had some slide issues with water previously so just wanted to make sure this was "normal ".
Old 07-20-2016, 12:45 PM   #10
x2 on the slide topper.
Epat is offline   Reply With Quote
slide, slide out, water
