Old 08-17-2016, 07:05 AM   #1
Question Weight limit on slides
We have a CC Silverback 5th wheel. Does anyone know the weight limit on the rear bunkhouse slides?
travelintates is offline   Reply With Quote
Old 08-17-2016, 07:58 AM   #2
Herk7769's Avatar
A lot depends on the size (width) of your slideout and the mechanisim that moves it in and out. The larger the slide, the heavier it is and the more beefy the motor and gearbox.
We have a 77 inch slideout and I loaded the pantry and put 2 cases of wine, 2 cases of water, and 2 cases of beer in the dinnette slide and it would not close. The clutch in the gearbox would just slip.
Moved stuff around and it closed just fine, for example.
If you are going to mod the slideout and you plan on a heavy load, you may want to call Lippert (assuming they made your frame) and ask about beefing up the slideout motor and gearbox.
HAM CALLSIGN - KC3FFW
Old 08-17-2016, 04:15 PM   #3
Thanks for the info!
slide, weight, slide out
