Old 01-02-2016, 05:46 AM   #1
wet floor over tires on both slide outs
I have just hauled for 2 days in some good rain and when I opened up on arrival I found my carpet wet it seems over the tire area on my slideouts.Anyone out there experience this; The rest of the carpet area away form the tires is dry
boo798 is offline   Reply With Quote
Old 01-02-2016, 06:50 AM   #2
Capt. Mike's Avatar
You don't say anything about your trailer, including brand or how old it might be, but FR had a problem with some brands/models where there wasn't enough clearance between the tires and the top of the wheelhousing. The tires rubbed on the plastic liner, and could rub holes in it. If that happened, it would follow that the plywood floor could get wet and soak through to the carpet.
Was it wet on both sides? Do you have slide-outs on both sides? Possibly a seal on the slide is leaking?
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
“It's not how old you are, it's how you are old.”Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 01-02-2016, 08:25 AM   #3
Let me add to Capt. Mike's answer. My 2013 Flagstaff had less than one inch between the tires and fender wells. I also had started to have the wet floor as you. At Goshen, FR dropped the axles, added a 2.5 inch spacer/lift kit, relined the wheel wells, replaced the slider seal and end dust seals. Solved the wet floor problem completely. As stated, FR is aware of the problem and was more than happy to solve it. Four techs under my TT about 1.5 hours, on uneven sloping grass field. WOW! Great service.
According to FR the problem occurred when my model was upgraded from 14" to 15" tire/wheels. Some frames were still in stock with a shorter axle mounting pad. Hopefully your dealer will be of some assistance. I would suggest a call directly to FR to keep the dealer honest.
Travel safe
2001 Ford F-350 Super Duty CC Dually, 7.3 Diesel
2011 Cedar Creek 36CKTS Touring Edition
FordHauler is offline   Reply With Quote
Old 01-03-2016, 05:27 AM   #4
thanks Capt Mike
We are in a 2011 Blue Ridge 3025 and we do have water on both sides at the slide out where the wheels are, Nothing behind the wheel area of the slide, Do you happen to know what models where having problems.
Old 01-03-2016, 05:49 AM   #5
Capt. Mike's Avatar
I am aware that Rockwood and Flagstaff, which are both built in the same plant, had this problem on travel trailers including Mini-Lite, Windjammer and obviously, from FordHauler's response, some 5th wheel models. Not sure about other brands, but a call to the Blue Ridge Service rep, Dan Dobecki, phone number (574) 206-7609) in Elkhart, IN would be a good place to start.
Good luck!
Mike and Yvonne
Old 01-03-2016, 05:54 AM   #6
thanks Capt Mike
Good luck!
I will give him a call tomorrow.Thanks again for your help
Old 01-03-2016, 12:21 PM   #7
I have the same problem with my 2015 Rockwood Roo 23IKSS. Floor wet after driving in the rain. The dealer worked on it a bit but not solved. I contacted the factory rep and he asked that I give the dealer another chance to fit it then if not corrected it will go back to the factory. I cannot believe they do not have an inner fender on these where the slide out seal is right over the tires. On my unit that is both sides since it is a two slide hybrid. Nice trailer except for this.
2015 Roo 23IKSS
2016 F150 SuperCrew 3.5 EcoBoost
Kanga99 is offline   Reply With Quote
Old 01-03-2016, 02:53 PM   #8
Maron
Send a message via Yahoo to Maron
We have a 2014 Rockwood 8329 and noticed a wet spot over the curb side slide on our last trip. In 2 years of owning it, this was the first time we drove thru rain. Hmmmmm
Maron is offline   Reply With Quote
Old 01-03-2016, 06:20 PM   #9
dbarr's Avatar
My Coachmen dinette slide would leak every time I drove in the rain. Water would run the length of the sweep seal come in at the rear. I added a second seal and haven't been wet since. There was also enough room to put my fingers past the seal all the way up to my knuckles...good place for mice to get in.Click image for larger version
'15 F150 Ecoboost Maxtow Scab '13 Freedom Exp. 233RBS
Days camped 2017-46, 2016 -56, 2015-33,
2014-47,
Years camping....52
dbarr is offline   Reply With Quote
Old 01-05-2016, 08:35 AM   #10
What did you use
Originally Posted by dbarr View Post
My Coachmen dinette slide would leak every time I drove in the rain. Water would run the length of the sweep seal come in at the rear. I added a second seal and haven't been wet since. There was also enough room to put my fingers past the seal all the way up to my knuckles...good place for mice to get in.Attachment 97209
Attachment 97210
Attachment 97211
What did you use for your seal. It looks like door seal? Any worries about catching on original seal? I can't make out what you are showing in the first two photos.It looks like a great fix.
slide, slide out, tire, tires
