08-29-2016, 06:39 AM
What is this part? Is it important?
Recently returned from a trip to Lake Chautauqua KOA in New York, put the slide out and found this on the floor in between the dinette and the stove. It appears to be part of a broken plastic disc. It has teeth on it (which I think are visible in the attached pictures. I have a guess as to what it is, but want some more experienced TT owners to chime in before I say--I don't want to lead anyone down a rabbit-hole to nowhere like I do when I take my car to the garage for repairs.
First picture shows the part with the teeth underneath--the other two are teeth upward. Any ideas would be appreciated.
Rockfossilman - Western PA
Rockwood UL 2604ws - 2013 F150 w/MaxTow
"I'm a man, but I can change, if I have to. . .I guess."
Red Green
"Quando Omni Flunkus Moritati"
08-29-2016, 10:21 AM
It could be...
1. Made in China...might be part of a navagation system upper rindout gear and toilet assembly from a Chinese rocket and/or from a kids stroller.
2. A part taken off the assembly floor area by a worker and left inside on purpose. They love to leave parts/pieces hidden when building these things. Their purpose is to drive us owners nuts trying to figure out what it is and where it comes from/belongs.
If you have a guess, please.....
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
08-30-2016, 10:38 AM
Maybe it was a knock out for a wire pass through in something?
Brian
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on a custom trailer.
08-30-2016, 11:03 AM
It's a quarter.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
08-30-2016, 11:18 AM
Originally Posted by Teamfour
It's a quarter.
I've been up for 29 hours. That made me laugh way harder and for much longer than i should have!
2008 Toyota Sequoia SR5 5.7L 10k tow package
2017 Rockwood 2702WS
Equal-i-zer 4 point, Prodigy 3 brake controller
2016 nights camped = 17
2017 nights camped = 4
08-30-2016, 12:14 PM
It's probably part of a wear pad that wore out. Any scuff marks on the smoother side? I can't tell from the picture.
2014 Blue Ridge 3715BH <- Read the saga
2013 Sierra 3500HD Denali CCLB DRW 4x4 Duramax w/ Reese 20K
USN Retired (26 years), but not Retired retired
Home Port Orlando
08-30-2016, 01:00 PM
Based on where you found it, I would guess it is a cover for part of the slide mechanism that broke off.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
08-30-2016, 01:50 PM
I suggest get with your division at FR. Make contact with a person so you can send picture
08-30-2016, 04:21 PM
I have a pretty good idea that is part of a reel that held wire/small cable that broke off one of the heads of the reel. So someone was probably running wire and dropped the reel breaking off the piece you have now. See on the left side ( picture 2) there is a formed curve? That's the hole found in wire reels so when done you can tie off the end to prevent unraveling. So I don't think it is a part for the RV.
08-31-2016, 08:27 AM
Director, FROG
I think that Chrisc40 might be right. I sent a link to this thread to Roger Beiler, one of the Service and Warranty Administrators at Rockwood. Here's his reply:
I am not sure what that is but I don’t think that is part of the camper. I can’t think of anywhere that we use anything like that in the trailer. It seems like a piece of debris or trash that was left in the trailer.
09-03-2016, 01:19 PM
Rabbit-Hole Comment
Since the part didn't appear until our 5th trip with the camper and having put the slide-out out and in over a dozen times, it seemed to me that the part must have a purpose. My "rabbit-hole" idea was that there are a row of several complete discs located between the slide floor and the living area floor. They facilitate a lower-friction surface for the slide to travel on when being deployed or brought in--I haven't decided whether they would be mounted teeth up or teeth down. The partial disc that I found is the remnants of one that broke when the slide was deployed the time I found it. An occasional squeak/squeal has also begun to occur on occasion when putting the slide out.
Red Green
11-04-2016, 07:10 PM
It's a quarter.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2200i generators
11-04-2016, 07:18 PM
Your response is as unhelpful as some of the responses I used to get from a smart_ _ _ science student in one of my classes. Thanks for the laugh. I'm convinced the part is related to the slide out mechanism and the tech at Campers Inn thinks it might be as well. The camper goes to the shop in December for this and some other warranty issues.
Red Green
11-07-2016, 04:30 PM
Actually, maybe you never owned an RV with a slide out? I wonder because you might remember that lots of stuff comes out from underneath the slide of a new RV when the slide is moved. That's because the workers just let stuff drop and leave it there so the slide is sweeping junk into the RV for quite a while. I worked in the wire business for many years, maybe ever since you were in diapers, and that part looks exactly like a broken piece of a plastic reel head of which I've personally seen a million times. Additionally, where that piece came from is in the very area where they would run wires making it even more likely it is a piece of reel.
I think you better hope I'm on the money because if that flimsy piece of you know what is a major part of your slide then you have problems much worse then trying to figure out what that part is. Your saying you're science teacher so I'm sure you can see clearly the logic (hopefully) behind what I just said. BTW, maybe you treat adults like you do your students and don't realize how condescending your tone is? If you need me to point out where your tone is condescending just ask and I'll be glad to point it out to you.
11-07-2016, 05:47 PM
I'm sorry I upset you, Chrisc40. I goofed by not quoting who I was responding to. I was responding to the "It's a quarter" response, and I was joking. By the way, I'm retired, 68 years old and I treated my students with great respect, typically laughing WITH my smart_ _ _ students. The TT goes into the shop Dec. 5 for warranty work, including the odd noises the slide is making when deployed and retracted.
Red Green
11-07-2016, 05:55 PM
I am going with something left by an assembler at the factory that just took some time to vibrate to where it could be visible. I have seen tools, wire connectors etc show up years after delivery.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
11-07-2016, 06:01 PM
Part of a plastic wire spool?
If the spool was partially full and dropped and a chunk broke off it might look like that.
11-07-2016, 06:28 PM
I considered the possibility of a chunk of a piece of a wire spool, but partially rejected the idea because the plastic is not brittle, has a rubber-like flexible feel and is somewhat concave on the toothed side. Next month, the techs at the dealership will get to check the slide for the odd sounds it makes when deployed and retracted.
Red Green
