Old 12-22-2018, 05:42 PM   #1
What is this thing on my slideout for?
I have a 2018 Forrester Class C 2291SF
There is a piece of hardware attached to the top of my slideout just behind the awning.
ID:	193390   Click image for larger version
Mstanlake is offline   Reply With Quote
Old 12-22-2018, 06:01 PM   #2
Mr. Dan's Avatar
Are you sure it's on the slide-out -- or just beside it?
It's an anti-unfurl gadget. There should be a lever on the topper spindle that would hang on this gadget should the topper try to unfurl while you're driving.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 74; booked = 12
Old 12-22-2018, 06:03 PM   #3
It's part of the anti-billow for the awning. If the awning tries to unroll as you are going down the road the little arm on the awning will hit that stop you have pictured.
cub22908 is offline   Reply With Quote
Old 12-22-2018, 06:07 PM   #4
The arm on the awning would do almost half a turn before hitting that, possibly the arm is in the wrong position, ti sticks straight out which will be a problem when I pout the cover on it.
Old 12-22-2018, 06:49 PM   #5
Lacey's Spring, AL
formerFR's Avatar
it's a SLAP BLOCK for the 'finger' of the awning end, which will keep it from unfurling during travel.... if you are driving in high winds, chances are you'll hear a big BANG! every now and then if the wind is getting under the awning and trying to unfurl it. The 'finger' is the stop mechanism that hits the slap block on the sidewall.
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx, 100,000+mi since '14... US, Alaska, and Canada... from W.C. Georgia, then W. North Carolina, now Lacey's Spring, AL : )
formerFR is offline   Reply With Quote
Old 12-23-2018, 06:48 PM   #6
MCTroy
Ok, I admit, I am a little slow to figure some things like this out. This post is interesting because I worry about the 2 electric awnings unrolling while traveling in our WJ. I have even had DH pull over just so I can run back and give them a tug.
So if that little thingy is too stop it unrolling, why doesn't it get in the way when we want it to unrolling? I am missing something. Is this just to stop the awning and not the arm?
If so, then, I will still be running back to check those awnings.
2015 Windjammer 3029 Diamond Edition
2018 Ram 2500
Ohio River Rat
MCTroy is offline   Reply With Quote
Old 12-23-2018, 06:58 PM   #7
bikendan's Avatar
That object is for slideout toppers, not regular awnings.
Equalizer WDH
Old 12-23-2018, 10:03 PM   #8
MCTroy
Thanks. Guess I will keep checking the awnings then... I don't trust them.
2018 Ram 2500
Ohio River Rat
Old 12-23-2018, 10:47 PM   #9
bob213's Avatar
Install one of these and then you can relax a little.
Save Your RV Awning with an RV Awning Travel Lock!
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
bob213 is offline   Reply With Quote
Old 12-24-2018, 07:43 AM   #10
MCTroy
I will do some research and try these. Thanks!
slide
