08-01-2018, 08:57 PM
#21
What he said.
2015 GMC Denali 3500 4X4 Duramax
2019 Cedar Creek 36CK2 (sold 4/21)
08-01-2018, 09:30 PM
#22
Originally Posted by grumpy0374
303 Protectant. It was developed speciffically to treat and preserve rubber and vinyl. Only.
Have treated the seals and gaskets on our Lexi for 6 years now. Treat every other month, and they are still as good as new.
You DO NOT want to use ANYTHING with a petrolium base, or anything containing oil of any type. It will eventually dry rubber out. Both WD40 and silicon contain petroleum, 25% for WD40.
All silicon and WD40 will do is prevent sticking. Does nothing to preserve the rubber or vinyl.
Baby powder may be OK, but when it gets wet, it is messy, and it dosen't last.
Lots have their preference, but at least try to use something that is specific for your needs. WD40 or silicon if thats your choice. But keep in mind that slide seals are expensive, around $3 bucks per foot.
Grumpy
Originally Posted by grumpyoldman
What he said.
That's cause you're both Grumpy....
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
08-02-2018, 12:11 AM
#23
Old Engineer
Silicone spray does NOT contain petroleum.
Silicone (not silicon) in a spray can does not contain any petroleum.
2019 Dynamax Isata 3 24RW
Smart Car Towed 4 Down
Quote: "When all else fails, read the manual!"
08-02-2018, 04:17 AM
#24
OK, siliconE may not contain oil. BUT, it does contain "petroleum distillates" and/or liquified petroleum gas"
Anyhoo, your choice.
Another great use for 303 is on your vinyl graphics. Using any type of carnuba based wax on vinyl graphics is a no-no. Will eventually dry the vinyl out. If you wax, avoid the graphics and wipe on 303 over the vinyl graphics.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
08-02-2018, 06:43 AM
#25
Old Engineer
The petroleum distillates are the propellants used to get it out of the spray can.
They are volatile and evaporate instantly, before the product reaches the surface the spray is being applied to.
As noted previously, the Silicone that is applied contains NO petroleum.
I would also note that 303 is not a lubricant.
08-02-2018, 07:14 AM
#26
303 is ment as a preservative. Never advertised as a "lube".
No need to "lube" rubber slide seals, but to treat and preserve them. I use 303 on my tires as a preservative, not as a "lube"
Anyway, you go ahead and use your siliconE or WD40 if it makes you happy.
OP wanted to know what to use, and having used 303 for many many years, gave my opinion, just as you gave yours.
No argument or pissing match intended.
Grumpy
08-02-2018, 07:28 AM
#27
Aerospace 303
08-02-2018, 08:03 AM
#28
Aerospace 303. Also use it on the tow vehicle door seals.
2018 FR XLR Nitro 35VL5
2013 Ford F250 SRW 4x4 6.7L, Air Lift 5K Ultimate,
B&W Turnoverball Gooseneck Hitch, Andersen Ultimate Aluminum 5th Wheel Connection
2008 Honda Goldwing, U.S. Army Veteran
08-02-2018, 10:00 AM
#29
Old Engineer
Grumpy
The original thread asked about a lubricant and preservative.
I am interested in the complete accuracy of the advice and information given here.
08-06-2018, 07:55 PM
#30
Been using silicone spray on the outside and talcum powder on the inside cushions for 12 years now. 2005 Sunseeker with 2 slides
08-06-2018, 08:16 PM
#31
Silicone slide out seal spray has always worked well for me. 303 is also a good product, but I use that on vinyl graphics and tires.
former 2017 Forest River Sunseeker 2250SLE owner - replaced by a Pleasure-Way Tofino and then an Ontour 2.0
08-06-2018, 08:25 PM
#32
Slideout seals
I use WD 40 water resistant silicone lubricant on my rubber seals and WD 40 dirt & dust resistant dry lube PTFE spray on my tracks.
08-06-2018, 08:29 PM
#33
Originally Posted by old40ford
I am curious, how many never use anything on their slide out seals?
I bet there are more than you think.
I fall into that category. 8 years and my seals still look like new. Tried it once, my seals were so slick the wipers stopped flipping in and and out . Never used it again.
Jason and Billie
2018 F-250, 6.2L
2011 Prime Time Crusader 320RLT
08-06-2018, 08:52 PM
#34
Canadian Member
08-07-2018, 01:12 AM
#35
Originally Posted by Old Oregoner
WD40 protects and rejuvenates all rubber
WD-40 will also act like a magnet for dirt. If I was willing to use wd-40, I use silicon spray instead.
But I'm not so I'll still to the 303
08-07-2018, 06:52 AM
#36
Used to use 303, but it made the sweeper seals too slippery to "flip" when the slide was opened or closed. Only use it on the D seals now.
2015 Flagstaff 21FBRS
2012 Silverado 1500 LT Ext Cab 5.3L 3.08
Blue Ox SwayPro 550
08-09-2018, 10:48 PM
#37
Liquid wrench dry silicone slideout seal spray.
Jim & peg. Jake the camper dog. RIP my friend. 01-11-2010 / 02-26-2020. 2018 flagstaff 8528ikws fifth wheel pushing 2014 f-150 eco-boost super crew. 2017 camped 14 weeks. 2018 4 months in texas. 2019 4 months in texas. 2019 21 days in michigan. 2019 2 months in arizona. 2020 4 months in arizona. U.S. Air Force Retired. 100% DAV
