07-27-2018, 05:43 PM
What to use on slideout seals to lubricate and seal
Have a Dynamax Dynaquest 32' 2006 with 2 slides. What would we use on the seals
around the slides to maintain the rubber seals and lubricate.
Right now the seals look in good shape and no rain coming in.
Just want to maintain seal texture and seal.
Thank you
07-27-2018, 05:45 PM
I've always treated our slide seals with Aerospace 303 three times a season.
07-27-2018, 05:47 PM
303 protectant
07-27-2018, 06:00 PM
303 on slide seals/entrance door seals/bay door seals/storage door seals/window Trim-Not Glass/Decals/Power Cords! Youroo!!
07-28-2018, 01:13 PM
and tires
2015 GMC Denali 3500 4X4 Duramax
2019 Cedar Creek 36CK2 (sold 4/21)
07-28-2018, 01:31 PM
303 has several different bottles. Which one do you use on the seals?
07-28-2018, 02:31 PM
Protectant
07-28-2018, 02:45 PM
On my boat 50amp cord which is permanently connected and runs thru a power retract l use mop & glow. It gets quite dirty feeding in and out around salt water and docks so must be cleaned with a solvent.The m&p acts as a protecterant. Just on the power cord though! 😎
2019 Dx3 TS
2020 RAM 1500 Limited Diesel 4x4
7 lb Guard Dog
Working hard on “elderhood”
07-28-2018, 02:58 PM
Just to be different and cheap and easy.... Baby Powder and a sock
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
07-28-2018, 03:59 PM
303 Protectant!
Thank you
303 fer shere...nothing *else! Follow the Dir's carefully. If you can get it on the top seal of the slide out then do that too(the part hidden by the mini-awning "shade" that deploys with the slide...I assume you have one?). I think you can apply the foam and work it in with a sponge attached to an extension handle, or the like.
PS: *else means "Armor All", etc. THAT stuff will work against the rubber and is not advised. Just use the correct "Protectant 303" product! Check eBay or Amazon btw, and let them deliver to you free shipping. And, not too sure re the baby powder\sock routine as that might tend to dry the rubber too much? 303 keeps it supple and pliable. Unless you like that baby-bottom smell, lol?
Si Hoc Legere Scis, Nimium Eruditionis Habes!
07-28-2018, 05:18 PM
303 makes a slide out seal conditioner also.
Retired Auto body teacher
2021 Arctic Wolf 3550 Suite
2019 F-250 Lariat Super Crew 6.2
Having lots of Fun traveling with my wife
07-28-2018, 08:02 PM
I use Thetford 32778 slide out rubber seal spray, Amazon
07-29-2018, 10:23 AM
How about the seals around frameless windows? Protestant 303 there too?
07-29-2018, 10:31 AM
I am curious, how many never use anything on their slide out seals?
I bet there are more than you think.
07-29-2018, 10:38 AM
vinyl, rubber, plastic...
2014 Shamrock 183
07-30-2018, 06:49 AM
Baby powder is what the Coast Guard uses on their exterior rubber seals
Sent from my SM-G930V using Forest River Forums mobile app
07-30-2018, 08:30 AM
Arvee Pilot
WD40 protects and rejuvenates all rubber
2019 FR3 30DS
Toad: 2010 Explorer Ltd
07-30-2018, 08:58 AM
X2. Have never used any conditioner on any slide seals on any rig I've ever owned. I figure using stuff like that sure can't hurt anything, but generally just makes the user feel better and helps the economy
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
08-01-2018, 06:15 PM
Old Engineer
Any Silicone Spray Works Well
Any Silicone spray works well, also use on basement door gaskets, keeps them from sticking.
2019 Dynamax Isata 3 24RW
Smart Car Towed 4 Down
Quote: "When all else fails, read the manual!"
08-01-2018, 06:27 PM
303 Protectant. It was developed speciffically to treat and preserve rubber and vinyl. Only.
Have treated the seals and gaskets on our Lexi for 6 years now. Treat every other month, and they are still as good as new.
You DO NOT want to use ANYTHING with a petrolium base, or anything containing oil of any type. It will eventually dry rubber out. Both WD40 and silicon contain petroleum, 25% for WD40.
All silicon and WD40 will do is prevent sticking. Does nothing to preserve the rubber or vinyl.
Baby powder may be OK, but when it gets wet, it is messy, and it dosen't last.
Lots have their preference, but at least try to use something that is specific for your needs. WD40 or silicon if thats your choice. But keep in mind that slide seals are expensive, around $3 bucks per foot.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
