Old 08-26-2016, 02:57 PM   #1
Where is seal location to manually move slide
We have s 2016 sunseeker and from what I have been told there is a seal some where that you remove to the use a wrench to manually move the side - if it is stuck. Looked all over inside and out can't find it. Thanks
Steveanddianne is offline   Reply With Quote
Old 08-27-2016, 10:26 AM   #2
grumpy0374's Avatar
I believe you'll find that the nut with the safety clip going thru and holding it on is the nut you turn to manually bring the slide in'out.. If you look, in your photo, it's attached to the gear box part of the motor/gear box assembly. Have the same set up on my bedroom slide on our Lexi. Front two slides have the manual nut accessable from the storage compartments just under the slides. Bedroom slide only accessable from under the bed.
Takes a 5/8 inch wrench or socket.
Grumpy
Steve & Cheryl + Charlie & Casey, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
Camping trips this year so far...8
Days camping...75
grumpy0374 is offline   Reply With Quote
Old 08-27-2016, 10:42 AM   #3
Thank you we appreciate the information
cat, location, manual, slide
