Old 12-24-2013, 08:12 AM   #11
Dave_Monica's Avatar
The motion you describe is normal...when in motion, the top stops first then bottom continues until it's seated, whether the slide is going in or out.
If the bottom still has a gap when closed, the stop can needs to be adjusted as described in the manual.
Dave
Old 12-24-2013, 08:34 AM   #12
Witch Doctor's Avatar
How they check your seal is that they put a piece of paper between the gasket and body, if it will hold it is tight enough.
Coachmen M/H
Concord
2018 / 300 DSC
slide
