Old 09-05-2016, 04:00 PM   #11
Evereddie's Avatar
Originally Posted by bubbles View Post
Look closely, the bottom nut is a nylock nut and therefore a locking nut. It is correct.
Yes I see it now. Makes sense but doesn't explain the clean threads. Especially the inside of the threads.
Sent from my SM-N900V using Tapatalk
There are 10 types of people in the world.
Those that know binary, and those that don't.
Evereddie is offline   Reply With Quote
Old 09-05-2016, 04:04 PM   #12
Still say all the nuts should be tight against the bracket.
Old 09-05-2016, 04:10 PM   #13
Evereddie's Avatar
Yes. Movement that was meant to be would only keep the tips of the threads clean. Not deep into the threads.. It's basic people. If there was movement designed into this area, there would be a collar around the threads.
Old 09-05-2016, 04:22 PM   #14
DDC
DDC's Avatar
Originally Posted by Bama Rambler View Post
That's a through frame slide. On page 16 of this manual it tells you how to adjust the nuts. They're not supposed to be snug against the bracket on both sides.
Thank you, reading this now it makes sense, typical cheap RV industry does not use a sleeve.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 09-05-2016, 04:25 PM   #15
Evereddie's Avatar
i can't disagree with the cheap RV industry part.
Old 09-05-2016, 04:29 PM   #16
northstar1960's Avatar
That would be typical cheap LCI components do not engineer anything well
northstar1960 is offline   Reply With Quote
Old 09-05-2016, 04:33 PM   #17
I will concede it is as it should be after reading the manual, but I, personally, would remove the bracket, enlarge the hole and make a tube spacer to protect the threads as the way it is now, after a few years of use, if you have to re-adjust it, the threads will be gone.
Old 09-05-2016, 04:41 PM   #18
bubbles's Avatar
If it was a fixed distance between nuts upon install then a sleeve could be used. It is a variable distance between nuts (periodic nut adjustments also have to be made after install in both directions) and I believe a sleeve would be impractical. JMO
Old 09-05-2016, 04:47 PM   #19
Then I would make different length sleeves. Once the threads are gone, further adjustments are difficult if not impossible.
Old 09-05-2016, 04:50 PM   #20
Evereddie's Avatar
You could have a bracket with a short sleeve built in. Then it wouldn't be a bracket edge rubbing on the threads.
Still wonder why the clean threads. Maybe someone in manufacturing put thick grease on that section knowing it gets a lot of movement and scrapping.
