Old 09-04-2016, 10:38 AM   #1
DDC
DDC's Avatar
Why would this be?
Weather is good so it's time to look for any more QUALITY or lack of issues, I came across this, one slide has a little float at the ram but this one has a lot, thing is I don't know which one is correct or if they should be loose at all.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 09-04-2016, 10:50 AM   #2
Canadiancrew's Avatar
I would not think they should be loose like this but going to check mine. It's at the storage yard right now so I can't just go out in the driveway to check.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
Canadiancrew is offline   Reply With Quote
Old 09-04-2016, 10:55 AM   #3
bubbles's Avatar
It's not loose. That is a slide adjustment for in and out travel and allows for even travel of the slide if there is more than one attached to the slide.
Old 09-05-2016, 11:37 AM   #4
Head Rambler
That's a through frame slide. On page 16 of this manual it tells you how to adjust the nuts. They're not supposed to be snug against the bracket on both sides.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 09-05-2016, 12:58 PM   #5
Based on the rust pattern on the bolt, it looks like that lower nut has moved recently.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is online now   Reply With Quote
Old 09-05-2016, 01:05 PM   #6
They should be tight against both sides of the bracket.
Old 09-05-2016, 02:08 PM   #7
Evereddie's Avatar
Using general engineering practices as a guide, if it was suppose to be that way there would be another locking nut on the bottom like above. Doesn't look right to me either.
Evereddie is online now   Reply With Quote
Old 09-05-2016, 02:39 PM   #8
litgrep's Avatar
Agree with Bama. Read the manual to check the adjustments. It's got a lock nut on one side and 2 nuts to lock on the inner. Lack of corrosion on the inside is due to movement in and out.
Roy and Gail with Rosie and Toby lucky dogs
2013 Salem Hemisphere 286 RLT
2009 Silverado 2500HD
litgrep is offline   Reply With Quote
Old 09-05-2016, 02:50 PM   #9
litgrep's Avatar
Old 09-05-2016, 02:57 PM   #10
bubbles's Avatar
Look closely, the bottom nut is a nylock nut and therefore a locking nut. It is correct.
