Old 02-12-2019, 08:22 AM   #1
Wildwood 27RE awning over slideout
Purchased the TT at the Tampa Show, except that particular model not displayed.
Does any member have that or another model with the 2 awnings? Could u post a photo of the awning over the slideout while deployed?
bvanoen1 is offline   Reply With Quote
Old 02-12-2019, 08:46 AM   #2
cavie's Avatar
Slide toppers are very generic as far as looks. If you've seen one you've pretty much seen the all.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 02-12-2019, 10:07 AM   #3
heavynlori's Avatar
I think OP is referring to the actual 2nd awning and not a topper....perhaps that model has two awnings and one of those extends over the slide instead of a topper
heavynlori is offline   Reply With Quote
Old 02-12-2019, 10:12 AM   #4
I believe so. And they always have the seam between the two right at the door so you get wet or its not big enough and the slide takes up 80% of the awning.
Kimber45 is offline   Reply With Quote
Old 02-12-2019, 12:09 PM   #5
That was the reason for my original request. Wanted to see how itís arranged with slide extended and both awnings deployed.
Old 02-12-2019, 03:19 PM   #6
Hope these pictures help.
ID:	196676   Click image for larger version
ID:	196677   Click image for larger version
ID:	196678   Click image for larger version
ID:	196679   Click image for larger version
mykie64 is offline   Reply With Quote
Old 02-12-2019, 04:08 PM   #7
cavie's Avatar
Old 02-13-2019, 09:22 AM   #8
They sure did. I wasn't sure where the rear awning was mounted. Did you ever consider mounting a dual direction fan in the bedroom?
Thanks again to all replies.
Old 02-13-2019, 11:11 AM   #9
No. I wish it did come with a roof hatch at least.
awning, slide, wildwood
