Old 07-03-2015, 07:07 AM   #1
Wildwood slider floor replacement
My floor on the dinette slider is rotten. Is there a way to replace it without removing the whole slider. I'm setup in a park full time so the slide is out full time.
winegen is offline   Reply With Quote
Old 07-03-2015, 09:43 AM   #2
Ford Idaho's Avatar
Depends on the extent of the rot.
If it is rotten under the walls odds are good it will need to come out and the walls removed.
Pull up the carpet and check it out use a scratch awl or grind down a broken screw driver.
Poke the floor wood at the wall in several places if the point goes in easy you have a problem.
Old 07-03-2015, 03:30 PM   #3
Checked it and it looks like just the floor. Pulled the paneling and seen where it's screwed to the floor so my guess is the slide has to come off. Need to make the floor first the pull it out.
replacement, slide, wildwood
