Old 01-10-2015, 11:40 AM   #1
Phat Phrog Stunt Crew
elind's Avatar
Winter operation of hydraulic slides.
I getting ready to go south for the winter with my Wildcat. I have 3 hydraulic slides that I have concern for using it during the extreme cold. We are packing up at below zero and need to open and close daily so the snow doesn't interfere the closing. Will the hydraulic oil get to heavy in the cold to put stress on the system? The oil weight in engines are adjusted to temps, is hydraulic the same?
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 01-10-2015, 12:22 PM   #2
Heavy Equip. for (Cold) operation requires a period of time for (Op Temp) these systems are diff.than the RV type. RV type are a (On Demand) type,so No warm Oil. Most RV hyd systems use ((Power steering type fluid or Auto Transmission fluid). Most Hyd. Systems LIKE WARM weather!! Youroo!!
youroo is online now   Reply With Quote
Old 01-10-2015, 12:35 PM   #3
If you can maybe put a heat lamp by the pump and reservoir to keep it a bit warmer
lbrunning is offline   Reply With Quote
Old 01-10-2015, 12:44 PM   #4
elind's Avatar
Youroo, I drove heavy equipment in the winter at a shop and sawmill. In the morning the hydraulics would grunt the first 5 minutes. If it uses a power steering or tranny fluid I would think it would operate a little more freely.
2014 Wildcat 327ck
Old 01-10-2015, 12:50 PM   #5
elind's Avatar
I'll just borrow DW's hair blow drier.
2014 Wildcat 327ck
Old 01-10-2015, 01:10 PM   #6
Ford Idaho's Avatar
I tried this just once, I now own a heat gun and I have fewer bruises....
Old 01-10-2015, 01:13 PM   #7
davel1971's Avatar
ATF type fluid isn't immune to being thicker in cold weather, but not as severe as heavier oils. I'm sure performance will slow in the cold though.
David & Lynn
Old 01-10-2015, 01:36 PM   #8
elind's Avatar
DW just said "a few bruises is better than unwrapping the power cord off my neck".
2014 Wildcat 327ck
Old 01-10-2015, 02:01 PM   #9
Lippert produced a notice re: Hydraulic Fluid and Temperature guidelines
LIP Sheet 0291 Dated Jul 16/13
Maybe this will help you decide what is the best solution/direction
See below for attachment
File Type: pdf LIP Sheet 0291-Hydraulic-Fluid-Recommendation.pdf (80.9 KB, 122 views)
mbtelguy is offline   Reply With Quote
Old 01-10-2015, 02:26 PM   #10
Zoo1392's Avatar
It's the change in viscosity at lower temps that will cause slower operation. Since most of the Hyd systems use ATF fluid and when the it gets below 40 degrees Fahrenheit (Kinematic Viscosity Testing is done at at 40C) it starts to get thick as it loses some of its ability to flow or viscosity.
You could use a synthetic transmission fluid as they behave much better and retain their given specs under cold weather conditions, but you would have to check with manufacture to see if it's compatible with the seals in the system.
Don & Rebecca
living can be broken down into two elements
Define the essentials
Eliminate the rest
Zoo1392 is offline   Reply With Quote
hydraulic, slide, winter, slide out
