Old 08-31-2015, 07:06 PM   #11
Well, I found a forum on this. It is a long time issue with Forest River, yet they won't do anything to fix it.
Some have fixed it with uhmw poly strips.
Our RV is still under warranty, and we are taking it in at end of month at the dealer where we bought it. I hope they will fix this on all slides so we don't have this problem again. We will see.
Thank you all for your help.
Tillville is offline   Reply With Quote
Old 08-31-2015, 07:22 PM   #12
I have a similar problem with my slide out on a new TT. The dealer said that FR left off some slide out rubber gasket at the bottom. It is in for repair. Another example of good manufacture PDI before leaving the factory. I guess the customer has to find the problems for the dealer to fix because of factory not doing their job.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
Old 08-31-2015, 07:34 PM   #13
Witch Doctor's Avatar
Originally Posted by Tillville View Post
What would I search for? I tried searching for wood showing under slide n 5th wheel, but nothing really came up.
I did read one place where they are used to having the underbelly having metal...they had just purchased another RV that doesn't have it and are concerned.
type in the search box DARCO WRAP, there is ton of stuff on it....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 08-31-2015, 08:16 PM   #14
Txredfish, did they say how long it will be in for repair?
Old 09-01-2015, 09:09 PM   #15
I have a 2015 Sanibel 3250 and it has the same problem on both slides, more on the kitchen slide.
Most Forest River (also Prime Time) fifth wheel trailers have this problem,
they have a slide out kit available .
This is a warranty issue and you should follow it up with Forest River.
My trailer goes in this fall to have this kit installed.
Hope this helps you!
wamafi43 is offline   Reply With Quote
Old 09-01-2015, 09:16 PM   #16
Plain Old Member
Majestic Formed Plastics makes glides (or whatever you want to call them) that go under each end of the slide. That's just one company and the product I've used on our last rig and this one. Some dealerships carry them, or you can get them directly from them. They're pretty inexpensive. Had them installed on last rig and newer one from day 1, no problem. It should be standard on ALL RV's, since most all flush floor slides have this same problem.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 09-01-2015, 09:19 PM   #17
Plain Old Member
Dave Rheinheimer (574) 320-4883 was the last contact I had for a guy with Majestic. Slide out end caps is another name. Some manufacturers have their own version, but are thinner. I prefer the Majestic ones, thicker. A lot have just made their own, which I'll consider in the future.
Old 09-01-2015, 09:29 PM   #18
Wamafi, I talked with a guy who had that kit put in and is going back into shop again as the kit didn't work.
Old 09-01-2015, 09:32 PM   #19
Big john, thanks for info. Definitely will check into this.
Old 09-01-2015, 09:40 PM   #20
I hope the factory kit works, my trailer is a brand new unit and it had the trouble right from the beginning.
Some of the owners on this forum said that it fixed the problem...
show, slide, slide out
