Old 04-29-2015, 10:06 AM   #1
XLR Hyper lite maual slide operation??
One of the schwintek motors went out on the slide. I removed the motor but can I run the one motor and manually push the slide in and out or do I have to disengage the second motor?
2013 XLR 27HFS
2007 GMC Duramax
creed is offline   Reply With Quote
Old 05-31-2015, 05:59 AM   #2
Was your slide in when you removed the motor? I have a bad motor and have been trying to figure out how to get to the screw on the outside of the camper so I can pull the motor. The trim on the slide is covering the screw.
dmnewland is offline   Reply With Quote
Old 06-01-2015, 06:12 PM   #3
Im running into the same problem. The motor on the rear of the slide doesnt work but the front one does.
dbprizer is offline   Reply With Quote
slide, xlr
