Old 09-15-2011, 03:35 PM   #1
Villa Estate 392FLFB
The_Stuff's Avatar
Yet another Slide-Out question
So the rear slide in my trailer does not seem to be lining up to the wall at the top. the bottom is square against the walls but i have about 1-2" of clearance from wall to slide gasket at the top of the slide.
is there a way to adjust the slide to lean out? and is this a do it your self job or get someone out that knows what they are doing?
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 09-15-2011, 04:17 PM   #2
The_Stuff's Avatar
I figured it out using this pdf i found on another thread.
http://www.lci1.com/OwnersManuals/Sl...ideout-Web.pdf
basically had to undo 2 bolts per ram, then loosen the up/down nut, move it so the top falls down against the wall and then tighten up again. easy to do just a pain to get under and do it and have to deal with the million spiders and webs...
ah credit goes to milzat
http://www.forestriverforums.com/for...html#post51681
Old 09-15-2011, 06:26 PM   #3
rbarrieau's Avatar
I just read your owners manual * I did'nt know you should cut the power before manually operating your slide. Good thing to know before something gets ruined.
Rich + Lori -2006 salem 27BHSS/2004 Avalanche
4:10 rearend - Roxy the puppy when allowed.
41 Days camped in 2011 and counting.
rbarrieau is offline   Reply With Quote
Old 09-15-2011, 06:43 PM   #4
Herk7769's Avatar
Right click on the manual link. Select "save target as" and then his manual will be YOUR manual!
HAM CALLSIGN - KC3FFW
Old 09-15-2011, 07:09 PM   #5
rbarrieau's Avatar
i saved it as directed but had a hard time finding the file.. my docs are filled with my daughters music --- and the file name is ELECTRIC SLIDE..
Old 09-15-2011, 07:21 PM   #6
Herk7769's Avatar
Windows 7 or Vista?
Click on your "start button" (The round dot with the windows emblem in the lower left corner. That will bring up the windows program menu.
In the upper right corner of THAT menu is your icon and user name. Click on that (the name or the picture) to open your personal folders.
Find the folder "downloads" You should find what you are looking for in there. Additionally, you can drag that folder to your desktop with the RIGHT mouse button held down and when you release the button a menu that contains "Create Shortcut" will appear. Left click on that to create a link to your download folder. Don't use "copy" because it will never update new downloads.
