Old 04-03-2016, 02:48 PM   #1
MNtraveler's Avatar
Yipes! Forester 2402R side slider roller(s)
Should read 2401R.
Just noticed today this slider has only one roller. Shouldn't it have two??
The roller is about 12" from the right side. The entire width is 6'. On the left side, it looks like there may have been a roller and if it squished out it may have caused some gouging. See photos.
Right side (aft):
Name:	ImageUploadedByForest River Forums1459712860.614985.jpg
Left side (fore):
Name:	ImageUploadedByForest River Forums1459712890.666464.jpg
Gouging?:
Name:	ImageUploadedByForest River Forums1459712910.901518.jpg
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 04-03-2016, 03:25 PM   #2
crunchman12001's Avatar
Looks to me like the 2nd roller is missing. Brand new unit?
2015 F-250 FX4
Old 04-03-2016, 03:38 PM   #3
SeaDog's Avatar
Sure looks like you are missing one side. Was just in MN last week
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 04-03-2016, 03:43 PM   #4
MNtraveler's Avatar
New in October.
2016 Forester 2401R
Old 04-06-2016, 08:25 PM   #5
MNtraveler's Avatar
Update: took to the dealer today. Got smart and asked to stop in at a set time for a 15 minute look-see rather than leaving it for a week. Dealer confirmed missing roller, took some measurements and pictures, and will have to confirm warranty and order parts. They say it's not a big deal as they can put the new one in without removing the room. Hot tip: Rather than trying to fix the stripped screw holes, they will install the new one 2" to the right. Brilliant! Lastly, the mechanic said there is an inside roller on each side as well as an outside roller (a newer improvement they had advocated to prevent tipping inward) so it's safe to use vs. if it was just sitting on one roller; now it sits on 3 vs. 4.
2016 Forester 2401R
Old 04-06-2016, 09:07 PM   #6
Good to hear. Are they able to do anything to fix the damage caused by the missing roller?
2015 F-250 FX4
Old 04-06-2016, 10:04 PM   #7
MNtraveler's Avatar
It really wasn't damaged, just mainly surface mars, fortunately. It's in an inconspicuous location too.
2016 Forester 2401R
Old 05-06-2016, 12:38 PM   #8
What were your symptoms I have a 2401r in the slide right behind the driver seat makes one heck of a lot of noise like metal to Wood
Dh5653 is offline   Reply With Quote
Old 05-06-2016, 02:05 PM   #9
MNtraveler's Avatar
No symptoms here, just a missing roller. What you describe can happen if something gets caught in the mechanism or under the floor such as a rock. I'd suggest getting a strong flashlight and look carefully underneath when in and out looking for what is scraping.
PS: also look for bolts protruding under the slideout floor. See next post!
2016 Forester 2401R
Old 05-06-2016, 02:13 PM   #10
MNtraveler's Avatar
Update: our dealer installed a new roller and said they figured out the reason the old roller had gotten knocked out. It was installed in a location in which the roller got hit by a bolt that holds one of the seatbelts in place. I'm not quite sure how that happened because there were no protruding bolts underneath that I saw. Anyway, how bizarre. Obviously they had to put the replacement in a different spot!
2016 Forester 2401R
forester, slide
