Forest River Forums
Sunline User Photos
Old 11-08-2011, 05:53 PM   #1
'09 5th Wheel Cedar Creek Winterization
Hi Everyone, I am brand new to 5th wheel's. Have always had motorhomes. Just picked up a 5th wheel Cedar Creek 34SATS this fall. Owners Mannual is not present with my campers. I need some help and guidance on winterization. I do not know where the fresh water holding tank drain is. It has a washer/dryer hook up that I am unfamiliar with. Can anyone out there help me with my first time winterization of my 5th wheel. Will greatly appreciate your help. Andy
AndyRay is offline   Reply With Quote
Old 11-09-2011, 04:08 AM   #2
cardinal4fun's Avatar
Not sure on the fresh water tank drain. It may come out of the bottom of trailer in the form of a tube with a cap attached. It would look like the low point drain caps.
The W/D at least the way I do it, once the low point drain is open I open up the valves for the W/D lines so they drain. Close the valves before adding the pink stuff. While pumping pink in I crack the valves letting the air out and pink to raise to valve. I do both that way and have not had problem.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
Old 11-09-2011, 07:09 PM   #3
too fast turbo sled
f1100turbo's Avatar
in the faq section theres plenty to read about winterization !
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (5)
f1100turbo is online now   Reply With Quote
Old 11-10-2011, 06:34 AM   #4
volunteer moderator
HI Andy! Welcome to Forest River Forums!!
I don't have your specific trailer so can't tell you exactly where the drain is.
If you crawl underneath and don't see it maybe someone here with the same RV will
chime in.
As far as the washer hookups I'd disconnect the washer and open the low point drains
and then open the washer hookup valves so the water can drain out of them.
Then I'd close them and do a normal "pump in the pink stuff" winterization.
If you have a washer there must be specific directions for it, hopefully found in the
washer owners manual.
Watch the video in our FAQ found here--
http://www.forestriverforums.com/for...-rv-16668.html
Good Luck!
Peace!
Dan & Rita D
2008 Rockwood 2502 Ultra Lite
2004 5.3L Silverado 1500 ext. cab 2WD
Reese dual cam hitch, AirLift load levelers
53 days camping in 2010, 47 in 2011, 12 in 2012
Old 11-10-2011, 03:00 PM   #5
hi my 08 sat has a drain on the left side behind the back wheel you cant miss it
gene17847 is offline   Reply With Quote
Old 11-12-2011, 06:33 PM   #6
Winterization, Thank You
Hey Everyone, First off, thank you for the warm welcome. I appreciate the responses I have recieved.
Gene- my drain is on the left hand side behind my back wheel also, I found it after your response. Thanks.
KyDan, Your information and especially the video helped to answer the questions I was guessing at.
Thank you everyone for your help and quick response.
AndyRay
» Online Users: 554
119 members and 435 guests
0721SSROO, 4bnabird, 4Jeeperz, 4runner freak, acadianbob, accumack, armye7, ayotte, BBuck, BigKidzFun, bignugget, BOBFIDY, bowtang2001, briangoodridge, bumper, buzzmonster, Cafjackracing, caper, cat1956, cdbus, comfun1, Cowracer, D-mo, DAISY BOYKIN, darkcloud, daveg, daw592, Dennis and Julie, dewcew72, dezeldad, DonG, donn, dtolar, dunnnc, Elidh, etbt1216, extremebike, Falcon35, flc, Flying dutchman, fordmantpw, FR28footer, frfan, GeorgieGirl, gerrym51, Great Horned Owl, grhodes50, herk7769, hitch hiker, hoovercab, Indy Steve, Jeep4Two, jjm901, JMF, jmswms, JoeR, jusme, keep camping, kentkings, kgmat, KKapa, Kricket, lbhird, lemoj1, LFugate, lmcleister, Lonewolfcry, lowbubba, mayorvic, mcbride5, merlin66043, MikeFresno, MilCop4523, Mkayers, Mnflyboy, MREZ, mrtodds, msbates, NeilM108, newby, nuisance, OffPavement, pg_rider, Pinesman, pmsherman, redfox217, Reneedann, retiredguy, Rickstermn, rkswyo, Rugged Brown, rvinman, Sailfish Bret, Sawdr73, shineysideup, Skabi, skipper194242, slogan, softwarejoe, southernsky, Stank Bait, Tee, tentcamper1, tessval, THELMALOUIE, tiny, tking01_2000, torben, TRAVLINOHIO, travyp, tshayn, TTNewbees, vp22er, wagon52, whj77372, wnytaxman, wolfpack21643, wpmcnutt, youroo
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
