Old 02-16-2016, 06:59 PM   #21
JohnF's Avatar
Originally Posted by MIFarmer View Post
The trick is finding a bike carrier that is "suitable for RV use" that fits the 1 1/4". I couldn't, and ended up with an adaptor. That makes it too sloppy and really stick out. Lots of straps needed to keep it from bouncing. Long story short, I'm going to cut the factory one off and add something less flimsy.
Try this. I welded one on my camper.
https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 02-16-2016, 10:11 PM   #22
I have a 2013 Cedar Creek 34RLSA with the 1 1/4" receiver. Hauled two bikes from Arkansas to Florida using a Yakima 4 bike carrier. Had a driver flag me down in Jackson, MS. My bikes were bouncing around and hitting the rear cap (no major damage but scratches on the decals. I had the bikes securely fastened to the carrier, but the carrier was moving enough to allow the bikes to hit the rear. I added a rope to pull the carrier toward the ladder which took some of the movement out, but in checking the bikes several more times down the road found they were still bouncing out of the rubber holders on the carrier. Ended up adding additional rope to tie the bikes more securely. On returning from this trip, installed a front receiver on my truck - no more movement or bouncing and I can keep an eye on the too. Only downside is they pick up more bugs!
cbari
Carroll & Betty Davis
2011 Ford F250 Superduty Powerstroke
cbari is offline   Reply With Quote
Old 02-17-2016, 04:25 AM   #23
2007 WildCat 32QBBS
05CrewDually's Avatar
My Wildcat came with an 1 1/4 reciever too. It worked but I never liked the flex so I cut it off and added my own 4x4x.25" square tubing with 3 2" receivers. Now I can pull my golf car trailer or build any other accessory rack in the future. As long as you only use it for a bike rack, the frame manufacturer may permit a qualified fabricator to change it without voiding the warranty. (Get the authorization in writing)
What about the bikes? Simple, I built a 2" reciever on my airride pin box. I use a tilting/folding 4 bike Thule rack that I found on sale @ Dicks Sporting goods. The bikes don't move, they're always in sight, and are more deterrent to theft. Also, the Thule rack comes with an adapter on it for the 2". The shank is actually 1.25" so it could be used in your stock hitch.
Pics= 1. Old reciever. 2. New reciever/crossmember. 3. & 4. Thule rack tilted up/down
ID:	99752   Click image for larger version
ID:	99753   Click image for larger version
ID:	99754   Click image for larger version
05CrewDually is offline   Reply With Quote
Old 02-17-2016, 06:46 AM   #24
2 yrs goes FAST
You can always wait and MODIFY after the warranty period ( generally 2 years).
Like that pin box hitch. Saw a couple of them 2 yrs ago in Myrtle Beach SC.
At my age would have to solicit help to bench press them up there 😩.
There was a day, BUT, that day was yesterday 😳
SilverbackMel is offline   Reply With Quote
Old 02-17-2016, 07:48 AM   #25
On my 2015 Cedar Creek the hitch is rated for 50lb It's coming off. I plan to install a sliding carrier. I don't plan on carrying anything on it, I just plan to sit my generator on it when I dry camp. I can't get DW on a bicycle.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 02-17-2016, 07:53 AM   #26
DDC
DDC's Avatar
I was thinking about this Click image for larger version
ID:	99757 As my bike is a fold down and in a bag and thought I could carry the 2000 yamaha generator in it when needed, I guess my concern is the twisting motion because nothing secures the ends.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 02-17-2016, 08:36 AM   #27
What I'm looking at is something that slides under the camper that's attached to the frame at the rear of camper. That way it's out of view for the most part
Old 02-17-2016, 09:14 AM   #28
Jim34RL's Avatar
I had that on my 2010, 318SAB Cougar. I used this once to carry my bikes on it . Never again the bikes were scratched and bounced around a lot. The sliding rack over time bent one of the retaining supports. This was one feature I never ever wanted again.
Just do a free body diagram place a load about 15 feet from the rear axle and 3 feet off of the ground, see what force are in play here. Unless your frame is really beefed up I can see cracking and damage to the tubing of the frame over time. Due to the loading that will be applied by this moment arm. Just my humble opinion as a retired engineer who design frames.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
Old 02-17-2016, 12:03 PM   #29
I can't see a problem because nothing will be on it riding down the road. There is a spare tire under the frame too and it doesn't bounce around
Old 02-17-2016, 12:20 PM   #30
beagle22b07's Avatar
Hitch
Originally Posted by mbienve View Post
get one of these to stop the bike rack from bouncing.
Roadmaster Quiet Hitch for 2" Trailer Hitches Roadmaster Hitch Accessories RM-061
Now that looks great for stopping the bounce. Thanks for sharing that. This forum is great.
Larry
Larry & Chris (Abbey & Brody camping cats)
2016 Ford F-150 XLT Sport, Super Cab, 3.5 EcoBoost, 3.55, 4x4, MaxTow w/36 gal fuel tank
2015 Rockwood MiniLite 2104S, EMS-30HW, Carchet TPMS
Days Camped: 2015 = 51; 2016 = 59; 2017 = 20
If you're lucky enough to be camping......You're lucky enough.
beagle22b07 is offline   Reply With Quote
bike, bike rack, hitch
