Old 01-30-2016, 06:24 PM   #11
Thank you for the manual.
Jonol is offline   Reply With Quote
Old 01-30-2016, 10:07 PM   #12
Originally Posted by Jonol View Post
Somme square wave inverter will read only 90 volts AC and this is normal and that will not damage the appliances.
X2
rzrnaz is offline   Reply With Quote
Old 01-31-2016, 12:25 PM   #13
CC75's Avatar
Originally Posted by racer4 View Post
The WFCO inverter is a Pure Sine Wave Inverter, so modified sine wave inverters have no bearing on the OP's observation.
I think the Silverback has room for 3 or less batteries, the Cedar Creek has room for 4 batteries. It looks like 2 batteries in picture above. 116V is within 120V +/- 10%% and OK.
If you have 2 12V batteries, consider adding a third battery. If you do, try to match the new battery with the existing batteries. Also check the gauge of the battery cables. I would hope for 2 AWG, not 4 AWG or higher (thinner).
The yellow light indicates "battery back up status". That is normal when not plugged into 120VAC.
http://wfcoelectronics.com/wp-conten...00-Manual1.pdf
Thanks for the manual.
The pic is old. I have since added a third identical battery. The new battery was only a few weeks older than the ones the dealer supplied. I did use 2 AWG cables to connect the batteries in parallel, with the positive and negative terminals going to the rig from most farthest apart batteries. (i.e. positive from battery 1 and negative from battery 3 to the rig)
CC75 is offline   Reply With Quote
Old 01-31-2016, 03:51 PM   #14
Busybeavers's Avatar
So with these upgrades to the 3rd battery and the cables, is your output voltage still at 116 Volts? Just wondering because I have a 16 RE and only 2 batteries and mine reads 116v.
Busybeavers
2016 CC Silverback 29RE
2012 GMC 2500HD 4x4
Crew/6.5 Bed
Pullrite Superglide
Duramax/Allison
Busybeavers is offline   Reply With Quote
Old 02-01-2016, 08:32 AM   #15
CC75's Avatar
Yes. The AC voltage did not change when I added the third battery. I have more reserve power. On long trips of 6 to 8 hours, with the fridge on, the voltage stays at 116V. I check it at every stop (which is every 2 to 3 hours), and when I get to my final destination, just before I setup. Since this is new to me, I do not want to miss a low voltage, and ruin the fridge.
I have seen it drop down to 114V once, when the fridge was running off the inverter all night, rig not connected to the truck nor shore power, about 8 hours. The batteries were about 70% discharged (i think it was bout that, did not write it down, but do not remember being alarmed by it, 50% discharged would have alarmed me, well I do not think I would have had a panic attack, but concerned)
Once I get the hang of this, I am thinking of installing a Trimetric Battery monitor along with 6V golf cart batteries to replace the cheap Sears DieHards. The idiot lights that FR has provided in the rig, just does not do it for me.
Eventually I plan on boondocking, and have a ways to go learning all this. This is my first real rig; had a Colman tent trailer before; this not the same.
Old 02-05-2016, 03:21 PM   #16
Seems that we are typically in the same learning boat as many others. Had a TT but gas refrig, really like the residential but creates problems like boondocking. I have a lot to learn, understand and hopefully not duplicate the mistakes others have made ahead of us. Thank you for your updated information. I hate to get rid of brand new 12 volt batteries, but I really like the idea of 2 6v golf carts batteries (Trojan if hope) and eventually move up to 4 -6v batteries, then investigate the gen vs solar deli ma. Good luck!
Busybeavers
2012 GMC 2500HD 4x4
Crew/6.5 Bed
Pullrite Superglide
Duramax/Allison
Old 02-05-2016, 04:37 PM   #17
With residential fridge you absolutely need a Trimetric. If you would have been alarmed at 50% discharged I would be beyond that at 70% discharged!!!! Bottom line is that you can't use the panel LEDs with a system like this. The Trimetric will be really good for your blood pressure! Then you can have 85%, 80% and all the rest.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 02-07-2016, 10:25 AM   #18
CC75's Avatar
Correction: oops. I reported 70% discharged, I meant 70% charge still on the batteries based on the volts I read off the batteries. 30% discharged is what I should have reported. As ScottBrownstein implied, 70% discharged would have been very bad.
Old 02-07-2016, 08:43 PM   #19
Don't try to over-engineer this. Several years into life on the road with a residential fridge, the worst problem is keeping the darn doors shut and the food inside. You should get days on battery. If the inverter hasn't shut down your fridge is getting the juice it needs. It can also keep food cold for another 1/2 day with out any power. Batteries last longer, up to 10 years, if not discharged below 50% regularly.
William & Sara
2012 Silverado 2500 HD DA
2014 Cedar Creek 38CK
Sterlingsilver is offline   Reply With Quote
battery, inverter
