We full time chisumbella, so when not traveling I shut off the inverter. Only use it when traveling. As far as the battery disconnect, I have it on all the time. If you don't full time you may want the disconnect off to save the batteries. The inverter should be on when you are not plugged into shore power and need the fridge running.
2019 Ford F-250 6.2l gas 430 E Lock
2015 Cedar Creek 34RL
MORryde IS 7000 LB
Kodiak Disc Brakes
