Old 02-05-2016, 04:28 PM   #1
keith52's Avatar
12 Volt Outlet
Just ordered our 36ckts and looked high and low for a 12 volt outlet. I couldn't locate any and the salesman didn't know if the factory installs any 12 volt outlets. Does anyone with a 2016 model have a factory installed 12 volt outlet? If so, what model CC and where is it located?? Thanks in advance
keith52 is offline   Reply With Quote
Old 02-05-2016, 04:30 PM   #2
Justice12t's Avatar
Cannot comment on your model but ran into the same thing with my Crusader. Ended up finding it behind the tv, had to pull the TV all the way out to be able to see it.
2016 Prime Time Crusader 294RLT
2016 Days Camped - 31
2017 Camping Blues - ...
Justice12t is offline   Reply With Quote
Old 02-05-2016, 04:36 PM   #3
keith52's Avatar
The model I ordered has the tv on a lift. Guess there may be an outlet in the mess of wires in the hole.
Old 02-05-2016, 05:09 PM   #4
racer4's Avatar
I asked about adding two 12V outlets in the bedroom to a factory ordered Cedar Creek 36CKTS. The salesman checked with his factory contact and was told yes, they will build those in for $50 each. Maybe it is not too late to add those to the order.
Chris and Pat
2016 Ram 3500 Cummins Aisin Dually, 4.10 axle, Auto Flex Air Ride Rear Suspension
2017 Cedar Creek 36CKTS, Disc Brakes
racer4 is offline   Reply With Quote
Old 02-05-2016, 08:16 PM   #5
BandJCarm's Avatar
What are you using these for?
BandJCarm is online now   Reply With Quote
Old 02-05-2016, 08:25 PM   #6
Blackhat6mike's Avatar
I installed a marine weatherproof 12vdc socket next to the wheel wells on both sides so I could plug my air compressor in for pumping the tires. West Marine has them, but they ain't cheap. You can wire them in directly to your power panel as most panels have unused fused circuits.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 02-05-2016, 10:58 PM   #7
keith52's Avatar
Power up a Winegard G2 portable satellite.
Old 02-06-2016, 07:46 AM   #8
BandJCarm's Avatar
I use Direct and a portable dish. No DC for that.
But that made me think...........does the CKTS have outside 120v regular receptacles?
Old 02-06-2016, 07:55 AM   #9
keith52's Avatar
Yes, one on the door side, one in the basement, and one in the wet bay.
Old 02-06-2016, 08:28 AM   #10
wmtire's Avatar
I glanced at one of these online. Are you sure it uses 12 volt power supply. The pic I saw had it plugged into a 120 volt AC.....but it also had a power inserter, which may be the difference.
Winegard Carryout G2+ GM-6000 RV Satellite Antenna
EDIT: Ok I see where the GM-2000 does indeed need a 12 volt power source.
http://www.winegard.com/help/images/2/24/2452321.pdf
I think BandJCarm was suggesting that you could just get a 120 volt to 12 volt converter and plug it into a 120 volt outlet, if you have 120 volt AC power where you are at. This would be the simplest solution, unless you don't have 120 volt AC power.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
12 volt, electrical
