Old 05-11-2015, 07:09 AM   #21
Certified Curmudgeon
Dealer installed...
Mike Dropped
Old 05-11-2015, 09:27 AM   #22
Jim34RL's Avatar
Originally Posted by spock123 View Post
You are right about that. Think about about it when you wire up battery's together how big the cable has to be, a small wire it's just a trickle charge
I don't know about your tow vehicles but I have always been able to charge my battery and run the slides in and out with my Ram when I had my 318SAB Cougar. Every once in a while I would forget to unhook the battery when we put the unit in storage. The parasitic losses from the camper would drain the camper battery; so the legs would not extend or retract. I would plug in the umbilical cord from the truck and work the legs and charge the battery overtime; as we drove the camper home from the storage lot.
I also relied on the truck's alternator to supplement the electrical needs when not hooked up to shore power when extending or retracting the slides. If I didn't do this the amperage from the camper battery was insufficient to power the slides.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
Old 05-11-2015, 10:34 AM   #23
SilverbackMel's Avatar
X2
Just got the Silverback out of 3 months in the shop. Forgot disconnect. Battery out😩. Tried to hook up from truck, dead. Got jump from RV center, all good.
Hooked and drove 2 hours. At destination all worked off the truck.
Those parasitic draws did me in. Now back on 50amp.
I also have a Dodge 2500 with 2 huge batteries.
SilverbackMel is offline   Reply With Quote
Old 05-11-2015, 03:58 PM   #24
Brentf next time I go to check on the rv I will get that info.
ttanous is offline   Reply With Quote
Old 05-12-2015, 10:46 PM   #25
We have 4 6 volt batteries in two battery boxes...1 of them is in the side storage where you have your level system and the other box is just side it in the front storage. Both boxes have been bolted to the floor of each storage space.
Truck 2013 GMC 3500 SLT HD Dully ,Ext.Cab,air bags.
Camper's:John,Angie,Coco & Norris
RV: 2011 Cedar Creek 34RLSA
Past RV's: Misc.tents,V.W.Campers('65,'69) 2012 Arctic Fox 25S.
[B]Camping Day's: Never Enough
Little John is offline   Reply With Quote
battery
